Version 3.9.0 | Published December 13, 2017 ©
Post Render Scenes
Scenes can be exported as video or image files. This process is called post rendering.
Note: Post rendering is not possible with clips or live video feeds. However, these items can be post rendered through the SoftClip plug-in, if it is animated through the stage.
Post Render Screen
The post render panel consists of:
Template (1) (see Post Render Templates)
Installed plug-ins are listed (2) (see Post Rendering plug-ins)
Post rendering setup (3):
Main Layer: Shows the Scene to be rendered. When Post is clicked, the Scene currently open will be set as the Main Layer
Front Layer: Set a Scene running in front of the Main Layer
Back Layer: Set a Scene running behind the Main Layer
Offset: Set an offset for the Main, Front and Back Layer, so they will start at different times
Stop: The number of seconds to pause during the animation stop points of a Scene. If there are stop points in the Scene, these are normally lost in the post rendering process, unless an interval is assigned here
plug-in property editor (4)
Server Panel (5)
Output (6)
To Post Render a Scene
Open the Scene to be post rendered.
Click Post. The Scene is loaded Main Layer target area.
Note: When Post is clicked, the Scene currently open on will be set as the Main Layer
Tip: It is also possible to click on Post, then select a Scene and drag it to the Main layer.
Set an Offset, if required. How the offset affects the Scene can be seen in the Post Rendering area.
Set a Stop (in seconds), if required.
This stops the post rendering after the assigned interval. -
Drag a selected post render plug-in, to Clip plug-in target area. Select from:
JPEG
PNG
MOV
TGA
TIFF
VideoRenderer
MatroxFileWriter. The Matrox File Writer plug-in requires a Matrox card. See Post Rendering plug-ins section for additional Matrox File Writer settings.
Select a frame Format. Viz Artist/Engine always renders 50 images per second for PAL or 60 for NTSC. Dependant on the post render format, not all of them or not the full frames are stored. Options are:
Full Frame: Store 50 or 60 full height frames for each second of video. The number depends on the video settings, PAL/50 or NTSC/60 frames, and the size also changes with the video format (720x576 for PAL digital and 720x486 for NTSC digital). Normally TV is 25 or 30 interleaved frames, but in this case the post rendering produces twice the amount of pixels needed. An editing system (or wherever you put the images you render) can throw away 50% of the pixels and still produce a “normal” video stream.
Fields Top/Fields Bottom: Store 50 fields per second of video. It is the same amount of data as interlaced top/bottom, but instead of shuffling the data the post rendering process writes different files for each field.
Interl. Top, Interl. Bottom: Store 25 interlaced frames for each second of video. Each frame consists of 2 fields (half size of PAL or NTSC for example 720x288). These two fields are combined line by line. Interlaced top means that the first line of the first field is the first line in the interlaced frame. In interlaced bottom the first line of the second field is the first line in the interlaced frame. This determines field dominance.
Full Frame Skip: Store every other full frame, resulting in 25 (or 30 for NTSC) frames per second.
Select the color settings. Select from:
RGB: Create RGB images. Here a pixel is represented by 3 bytes containing a red, green and blue sample.
RGBA: Create a red, green and blue sample, along with an additional color sample, all in a single image. When shown on top of other images, RGBA pixels are blended with the background pixel according to the value of this alpha component.
RGB AAA: For each image rendered, an RGB and an Alpha image are created.
Note: These settings are already fixed for the Matrox File Writer (see Post Rendering plug-ins).
In Name, select a destination file path and name.
Tip: When a Scene is added to the Main Layer, the path and filename are automatically assigned. To keep a previously selected path, click the Keep Path button (small rectangle to the right of the Name field).
Tip: With the cursor over Name a tool tip shows the path name.
Set the parameters for:
Duration: Set the number of frames to be rendered.
Width: Set a scaling value for the width.
Height: Set a scaling value for the height.
Tip: To scale the height and width proportionally click . When disabled the lock height and width scale can be set separately. The default setting is locked.
Click .
At any time, while rendering, click to stop the rendering. When the rendering is stopped the file(s) already written will be kept.
If Scenes are post rendered often, with the same settings, create a Post Render Template. To use a saved template double-click it in the Template panel.
Note: Post rendering templates are saved in the Graphic Hub and not on the local machine.
To Save a Post Render Template
Configure all the settings in the procedure To Post Render a Scene.
In the Templates panel, click Save.
Enter a name for the template.
Click OK.
Saved templates show in the Templates panel.
To Change a Post Render Template
Double-click the post rendering template in the Templates panel.
Change the required settings.
Click Save.
To Load a Post Render Template
To Rename a Post Render Template
In the Templates panel, right-click the template and select Rename.
Enter a new name and click OK.
To Delete a Post Render Template
In the Templates panel, right-click the template and select Delete <name>.
Post rendering plug-ins define the format of the post rendered files. Viz Artist offers a set of image and video rendering plug-ins:
Note: Additional plug-ins can be installed at any time.
Image Render plug-ins
Image rendering plug-ins, such as JPEG, PNG, TGA and TIFF, will all create a single image of every frame in a Scene. The images are named as set in the Name field in the post render setup, with incremental numbers.
Some of the plug-ins offer a Quality setting that allows to setup the quality level of the jpeg images to be created.
Video Clip Render plug-ins
The video rendering plug-ins render a Scene to a Video clip. If the Video Renderer or QuickTime Renderer plug-in are used, a menu showing all installed video codecs will show:
Available Codecs: List all available codecs.
Codec Settings: Shows the available codec settings (if available).
Codec Info: Shows information about the codec (if available).
FPS: Set the frame rate per second
Flicker Filter: Set the Flicker filter rate
Select the codec to be used and specify the parameters for Frame rate and Flicker Filter. If the video codec allows, specify codec parameters.
The Matrox File Writer plug-in is also a video rendering plug-in that is available to users with a Matrox board installed, and will render the Scene into a Matrox encoded clip. It uses the Matrox video board to encode and write clips to file in real-time.
Note: The Video Output DVI out setting must be set to Inactive (see Viz Configuration).
When a Scene is to be Post Rendered (To Post Render a Scene),
Note: These additional settings for the Matrox File Writer plug-in:
Pipeline Size: The number of internal buffers in frames for the matrox framework to operate. for SD+720p+1080i should be around one second (~25-30). It is recommended that you leave the default values.
TDIR Interval: Set the interval time, in seconds, to update the video file while it is recorded. The value must be 1 or more (less than one will not activate the TDIR feature).
Note: TDIR is only supported on ’.avi’, ’.p2.mxf’, ’xdcam.mxf’, ’xdcam_422.mxf’, ’.mov’, and ’.wav’ containers. The MATROX_MOV .mov containers write a separate file (<basename>.Ref<.extension>) that is updated to read the .mov file. This reference file needs to be used while the file is growing. The QT_MOV containers update the .mov file directly.
CreateVideoFile: Set to On to create a fill clip.
CreateKeyFile: Set to On to create a key file.
CreateAudioFile: Not in use.
CreateVbiFile: Not in use.
CreateProxyFile: Set to On to specify a custom resolution copy of the clip. These settings behave in a similar manner to the video file options and show when this is set to On.
Video Resolution: Shows clip resolution information.
