Version 3.9.0 | Published December 13, 2017 ©
Scene Tree Shortcuts
General Shortcuts
Function
Show Tree View
Ctrl+1
Show Sort View
Ctrl+2
Show Search View
Ctrl+3 or Ctrl+F
Show DVE Media Asset Manager
Ctrl+4
Show Texture Media Asset Manager
Ctrl+5
Refresh
Ctrl+R
Select all Containers
Ctrl+A
<Ctrl-Shift-A> toggles the auto grab focus. This is toggles the auto grab focus to and from the Property Editor. When auto grab focus is on the Property Editor, the shortcuts below do not work.
Tip: This enables a user to work with objects without the need to click into the Property Editor again.
Function
Key and/or Mouse
Go to Top Container
Home
Go to Last Container
End
Go to top of page
Page Up
Go to bottom of page
Page Down
Scroll up the Container list
Cursor up
Scroll down the Container list
Cursor down
Open or close the Container tree
Return, or the numeric keyboard Return
Basic View Controls and Shortcuts
Function
Key and/or Mouse
Insert New Container
Ctrl+Insert The new Container will be created above the first selected Container.
Multi select Containers
Ctrl+Right click
Delete Selected Container(s)
Ctrl+Delete
Open Tree
Ctrl+O
Collapse Tree
Ctrl+I
Lock Selected Container(s)
Ctrl+L
Unlock Selected Container(s)
Ctrl+Shift+L
Group Selected Container(s)
Ctrl+G
Ungroup Selected Container(s)
Ctrl+Shift+G
Hide Selected Container(s)
Ctrl+H
Show Selected Container(s)
Ctrl+Shift+H
Undo
Ctrl+Z
Redo
Ctrl+Y
Save the Scene
Ctrl+S
Copy Selected Container(s)
Ctrl+Left click on container name and drag
Copy Selected Container(s) to Clipboard
Ctrl+C
Paste Containers from Clipboard
Ctrl+V They will be created one hierarchical level underneath selected container.
Cut Selected Container(s)
Ctrl+X
Move Selected Container(s)
Move Selected Container and retain transformation properties
Alt+Left click on container name and drag
Copy Properties of Container
Left click on container Properties and drag
Merge Group
Ctrl+M
Split Container
Ctrl+Shift+M
Sort View Shortcuts
Function
Key and/or Mouse
Sort by Vertices
Ctrl+Q
Sort by Render Time
Ctrl+W
Sort by Texture Size
Ctrl+E
Toggle Unique for Texture Size
Ctrl+T
