Version 3.9.0 | Published December 13, 2017 ©
Soft Mask
images/download/attachments/27789686/viz_icons_softmask.png
The Soft Mask plug-in applies a soft mask to an object (e.g. image or geometry).
images/download/attachments/27789686/plugins_shader_softmask_scene_example.png
Note: This plug-in is located in: Built Ins -> Shader -> Effects
Soft Mask Properties
images/download/attachments/27789686/plugins_shader_softmask_editor.png
  • Progress: Move the mask perpendicular to the mask direction. Default is 0.0 and is based on the configured center position.
  • Rotation: Rotate the mask around the center.
  • Center X and Y: Define the X and Y position of the center the mask will have.
  • Gradient Width: Set the size of the gradient.
  • Invert: Invert the mask.
  • Mirror Gradient: Mirror the mask on both axis.
  • Blank: Offset the area that should not be affected by the mask.
  • Tracking: The progress can be controlled by a tracked Container to build the progress animation easier. Drag a Container to the drop zone.
