Version 3.9.0 | Published December 13, 2017 ©
Text FX Slide
images/download/attachments/27789481/viz_icons_tfxslide.png
The Text FX Slide plug-in allows you to create a sliding animation of the characters on the X, Y and Z-axis.
Text FX Slide Properties
images/download/attachments/27789481/plugins_container_textfx_slide_editor.png
  • X, Y and Z Distance: Defines direction and distance of moved text.
  • Show Direction: Enables and disables view of ‘movement’ vector.
    Note: The direction will not be shown in On Air mode.
