Parameters for the Chroma Keyer (including the Precision Keyer) can be applied by using shared memory and Viz Engines internal scripting language. No need to send a lot of commands to the Viz Engine. And in additional, shared memory values can be stored on Graphic Hub.
Sample Script
The following sample explains how to set and apply Chroma Keyer parameters:
sub OnInit()
dim key as string =
"preset1"
'fill shm map with keyer test parameters
system.map[key] =
1
'define base key
system.map[key &
".KeyHueAdjust"
0.2
system.map[key &
".KeySaturationAdjust"
0.21
system.map[key &
".WhitePoint"
0.22
system.map[key &
".BlackPoint"
0.23
system.map[key &
".GrayPoint"
0.24
system.map[key &
".ProcessFGGain"
0.25
system.map[key &
".DenoiseRadius"
2
system.map[key &
".DenoiseSharpen"
0.26
system.map[key &
".BackingPlateRGB"
] = cvertex(
0.27
0.28
0.29
system.map[key &
".Shrink"
3
system.map[key &
".EdgeWidth"
4
system.map[key &
".EdgeBlur"
0.3
system.map[key &
".EdgeLightWrapGain"
0.31
system.map[key &
".SpillLightWrapGain"
0.32
system.map[key &
".LightWrapRGB"
] = cvertex(
0.33
0.34
0.35
system.map[key &
".EdgeLightWrapRGBGain"
0.36
system.map[key &
".SpillLightWrapRGBGain"
0.37
system.map[key &
".LightWrapBGBlur"
0.38
system.map[key &
".CyanGain"
0.39
system.map[key &
".YellowGain"
0.40
system.map[key &
".MagentaGain"
0.41
system.map[key &
".AddShadows"
false
system.map[key &
".InnerShadows"
0.42
system.map[key &
".OuterShadows"
0.43
system.map[key &
".ShadowsGain"
0.44
system.map[key &
".ShadowsOffset"
0.45
system.map[key &
".AddHighlights"
true
system.map[key &
".InnerHighlights"
0.46
system.map[key &
".OuterHighlights"
0.47
system.map[key &
".HighlightsGain"
0.48
system.map[key &
".HighlightsOffset"
0.49
'apply keyer preset to video in
1
System.SendCommand(
& scene.vizid &
"*VIDEO*VIDEOIN*1*KEYER_PARAMS_SHM SET "
& key)
end sub
To Save and Load Shared Memory Keys from Graphic Hub
Shared Memory Maps can be saved and loaded from Graphic Hub.
Function LoadFromDb(path As String) As Boolean: Loads the contents of the map from a database file. The file is specified by path, which must be an absolute path, such as /User/mem_map.
Function LoadFromDbAsync(path As String) As Boolean: Loads the contents of the map from a database file. The file is specified by path, which must be an absolute path, such as /User/mem_map. This function is called asynchronous, the value does not have to be loaded when the function returns.
