This section details how to create, assign and work with Web Channel media assets.
Render Layers
Web Channels allow a designer to use up to 8 HTML-based render layers. They can be used either as Texture or as DVE effect.
Requirements
Web Channels only require a valid URL. Once entered, the webpage is rendered and can be interactively used.
Blending
If you want to blend your webpage against any background in DVE mode, make sure your are using the following order:
Info: Audio Mixing and Alpha are not supported.
Info: Keyboard/mouse interaction is supported only in DVE mode.
