The following shortcuts are valid for the Asset View:
Action
Default Key and/or Mouse Shortcut
Configurable
Renames an item
F2
(tick)
Focuses on the search input field
CTRL + F
(tick)
Copies the UUID of the item to the clipboard
CTRL + U
(tick)
Copies the path of the item to the clipboard
CTRL + SHIFT + U
(tick)
Checks in an item
CTRL + I
(tick)
Checks out an item
CTRL + O
(tick)
Adds a new scene or classic material (if the type is selected)
CTRL + N
(tick)
References search on this item
CTRL + R
(tick)
Exports file (if supported)
CTRL + E
(tick)
Increases Icon Size
CTRL + +
CTRL + Mousewheel
(tick)
Decreases Icon Size
CTRL + -
CTRL+ Mousewheel
(tick)
Copies
CTRL + C
(tick)
Cuts
CTRL + X
(tick)
Pastes
CTRL + V
(tick)
Shows icon view
CTRL + SHIFT + 1
(tick)
Shows list view
CTRL + SHIFT + 2
(tick)
Shows detail view
CTRL + SHIFT + 3
(tick)
Selects all items
CTRL + A
(tick)
Shows properties
CTRL + P
(tick)
Duplicates file (needs to be copied first)
CTRL + SHIFT + V
(tick)
Quick Look
SPACE
(tick)
