The information in this section relates to the VizCommunication.Map Data Sharing mechanism. A local VizCommunication.Map in each Viz Engine (as part of a cluster), collects and stores data. This data can be internal data, like a scene script pushing data to the map, or data from external control applications through TCP or UDP.
See also:
  • Viz Engine REST Interface – read and write the shared memory maps over HTTP (/api/v1/shm/...).
