If the total bandwidth of all connections exceeds the available bandwidth or if an input or output needs to be moved explicitly to the second SFP pair, the following applies:
Connectors on the second SFP pair start at the values listed below:
- Video connectors on SFP C start at 17.
- Audio connectors on SFP C start at 129.
- Ancillary data connectors on SFP C start at 33.
Information: For inputs this happens automatically during configuration based on the nominal bit rate of the selected resolution.
Examples
Example 1
Single Channel setup with ten 1080p inputs, input configuration:
- Input channel 1 - 8 mapped to IP input 1 - 8.
- Input channel 9, 10 mapped to IP input 17, 18.
Example 2
Dual Channel setup in UHD with fill/key, output configuration:
- Viz Engine 1 program output mapped to IP output 1, IP output 2 is used by the key.
- Viz Engine 2 program output mapped to IP output 17, IP output 18 is used by the key.
