Slot/Card Configuration
Slot
Usage
Slot 1 - Gen5 x16
Graphics Card (single Slot only)
Slot 2 - Gen5 x16 or x8
Matrox Video Card (X.mio3, X.mio5, DSX LE4)
only runs x8 speed if Slot 3 is used
Slot 3 - Gen5 x8
Other Expansion Card (Serial, GPI)
Information: Matrox AES Audio can not be installed. Larger Graphic cards will not run in Power redundant mode and are not tested by Vizrt.
Default Hardware
  • Single CPU 10-Cores
  • ​Dual redundant Power
    • Supply ​675W Platinum redundant, hot-swap
  • ​PCIe Gen5 Slots ​
  • Three PCIe Slots
  • ​64GB DDR5
  • ​1x 512GB M.2 (Front) + 1x 1TB M.2 (internal)
  • ​1x Gbit RJ45 onboard ​
  • 1x 10Gbit RJ45 Flex IO Slot
  • OS Support:
    • Windows 10 LTSC 2021
    • Windows 11 LTSC 2024
  • GPU Support:
    • ​A4000
    • 4000 Ada ​
Bios Settings
  • Security/Secure Boot Configuration Secure Boot: Enable
  • Advanced/Built-In Device Options:
    • Increase PCIe Idle Fan Speed(%): 30
  • Advanced/Power Management Options:
    • Hardware P-States: Disable
    • S4/S5 Maximum Power Savings: Disable
    • PCI Express Power Management: Disable
  • Advanced/Performance Options:
    • Workload Configuration: I/O-Focused
  • Advanced/Power Supply Options:
    • Power Supply Mode: Redundant
