Configure Shared Memory Output channels from this panel. The shared memory output is only available on systems with no video boards, or if Check Video Card is set to None
in the Video Board section.
Shared Memory Output: Sets the output mode for Shared Memory. Options are
Active
orInactive
.Color Format: The format the Shared memory texture is using: can be
YUVA4224
orRGBA
.Unique Identifier: Changes the name of the Shared Memory if required. Used when connecting to services such as Viz Coder.
