In the Destination panel tab, you can create rectangles that are then available in the Viz Mosart UI for assigning sources to newsroom tag destinations, while the template is in either Preview or Program.
Press Add to create a selected target area.
The target areas display in the Viz Mosart UI as drop down boxes. They become clickable if a source or shortcut is selected by the user.
See also section Program Window in the Viz Mosart User Guide.
