Working with the iNEWS Timer
The iNEWS Timer provides accurate timing of the production in iNEWS, and is used to synchronize the current Viz Mosart on-air story in the GUI, with its corresponding entry in iNEWS.
Connection
Connected to a local iNEWS client and the remote Mosart server, this application sends a shortcut to the iNEWS client each time an item is stepped through in the Viz Mosart story.
To set up an iNEWS Timer
Info: iNEWS Auto Timer application must be started with Administrator privileges, to be able to send shortcuts to the iNEWS client.
  1. First run: From the Viz Mosart installer directory, run VizMosartINEWSTimer-nnn.msi
  2. Start iNEWS Timer from the desktop shortcut.
  3. After the iNEWS Timer starts, a console Viz Mosart - iNEWS Auto Timer opens.
    Type settings in the console, to enable configuration.
  4. Make the following configurations:
    1. ApplicationProcessname: Name of your local iNEWS Client process. Default: ANWS.
    2. KeyStrokeHome: iNews client shortcut to reach top of rundown. Default: ^{HOME}.
    3. KeyStrokeTimeMarker: iNEWS client shortcut to be executed at each story. Default: {F12}.
    4. MMServerHost: Mosart Server hostname/IP. Default: none.
    5. MMServerHostB: Mosart Backup host. Default: none.
    6. ShowKeyStrokes: Display sent keystrokes. Default: false.
    7. ShowWindow: Determines how the iNEWS Client window will behave when the KeyStrokeTimeMarker is sent. Default: 5.
      0: Simulates an Alt+Tab switch to the iNEWS Client window
      1: Maximizes the iNEWS Client window, then brings it to front
      2: Brings the iNEWS Client to front without changing window state
      3: Same as case 1
      default Same as case 0
  5. In the iNEWS client, there are some steps needed to configure an iNEWS keyboard shortcut for triggering the Sync Timing feature on the selected story:
    1. In the iNEWS client, open Tools > Options > Preferences menu, to determine which keyboard is in use, for example DEFAULT:
    2. Open the Queue SYSTEM.KEYBOARD.XXXX where XXXX is the keyboard is in use (for example, DEFAULT).
    3. Add the F12 TIME MARK shortcut for triggering Tools > Sync Timing.
      (If something other than F12 is configured as KeyStrokeTimeMarker, adapt this to suit that setting).
      {alt t}: Selecting Tools top menu tab
      {shift s}: Selecting Sync Timing
      ;F12 Time Mark
      @{f12}~{alt t}{shift s}
    4. After making changes in your keyboard shortcuts, reload them:
  6. AIR-END and AIR-DUR values are now displayed for each story:
Command Console Commands
  From the iNEWS Auto Timer command console you can enter the following commands:
  • help
  • SETTINGS: Open the Settings window
  • SEND [keystroke]: Send a keystroke
  • SENDHOME: Sends the currenthome message
  • SHOWWINDOW [int]: Window position
  • SHOWKEYSTROKES [y]: Shows the sending keystrokes
  • PRCNAME [ProcessName]: Details on running process.
See also: Avid iNews Web Service for Status Feedback.
