Viz Mosart has several individually password-protected features. These are independent of HTTPS and OIDC, and apply whether or not authentication is enabled. On the desktop applications, they are the main access control alongside network isolation.
Template Editor password
Password protection can be enabled for the Template Editor. When enabled, the user is prompted for the password when opening the Template Editor. By default no protection is enabled.
See Setup and Administration of Template Editor and Configuration Issues.
GPO
Authentication to a GPO password-protected connection is set in AV Automation under Devices > Properties > GPI/O.
See GPI/O.
Generic REST driver credentials
When Viz Mosart calls an external REST service, the credentials it presents are configured on the device. The available authentication types are described in Authentication types on the Generic REST Drivers page.
Info: This is Viz Mosart acting as a client. For securing Mosart's own REST API, see Securing the Mosart Server in this chapter.
Vizrt Graphics MSE database
User: username on the Oracle database. Default: pilot.
Password: password on the Oracle database. Default: pilot.
Datasource: TNS name or connection string of the Oracle database. Default: vizrtdb.
Schema: Oracle database schema for the Viz Pilot connection. Default: PILOT.
See Graphics (Vizrt Settings).
TriCaster
TriCaster API credentials are required, and are initially set to admin / admin.
Note: Contact the TriCaster administrator, or sign in to the TriCaster Administration panel, to manage these values.
