vtefi_connection
view vtefi_connection is an alternative to the tdfi_connection table.
The tdfi_connection table is a relation between the td_templatedescription and fi_fields table while the vtefi_connection view provides a relation between the te_template and fi_fields table.
This means there is no need to access the td_templatedescription table directly.
The view is a join between the td_templatedescription and tdfi_connection tables.
Info: The vtefi_connection view only returns fields for templates description belonging to the gallery with ga_recno = 1. This is added by default and equal to the SHARED gallery.
Name | Type | Allow Null | Description |
vtefi_te_recno | integer | No | Foreign key referencing the template te_recno in the te_template table. |
vtefi_fi_recno | integer | No | Foreign key referencing the corresponding field fi_recno in the fi_field table. |
vtefi_default | varchar(128) | Yes | Optional default value for fields not of type ENUMERATION (i.e for STRING and NUMBER types). |
vtefi_em_recno | integer | Yes | Optional foreign key for the default value for ENUMERATION field types. Reference to a enumeration value em_recno in the em_enumerationmember table. |
Info: Template description as stored in the td_templatedescription table that relates to the shared gallery (ga_recno=1) is defined to be shared information (common between all galleries).
When the template description is updated from a gallery, a copy is made for the corresponding template description related to the shared gallery.
