The ta_templatetypealias table contains custom user aliases for the Mosart template types. These aliases are used by Mosart ManusAdministrator to translate user aliases to the corresponding Mosart template types.
Name | Type | Allow Null | Description |
ta_recno | integer | No | Primary key. |
ta_name | varchar(32) | No | The template type alias name. Should be unique, as this is presented to the users. |
ta_description | varchar(128) | Yes | Optional template type alias description. |
ta_tt_recno | integer | No | Foreign key referencing the corresponding Mosart template type in the tt_templatetype table. |
ta_default | smallint | Yes | A value of 1 is used for the ‘default’ alias among those belonging to the same template type. For each template type, exactly one alias belonging to that type should have ta_default = |
Information: The ta_templatetypealias table is the only table that is maintained and used by Mosart ManusAdministrator containing the NRCS template type aliases.
