The table te_template contains the individual templates with information that is shared among all galleries.
Note that information regarding a single template is divided into three parts / tables:
te_template: Contains basic template information. This information is shared among all galleries (i.e. gallery independent).
td_templatedescription: Contains typically template information to be presented to users that is gallery dependent.
ti_templateimplementation: Contains the template implementation as created by the Mosart template editor. This information is gallery dependent.
Name | Type | Allow Null | Description |
te_recno | integer | No | Primary key. |
te_ts_recno | integer | No | Foreign key referencing the corresponding template set in the ts_templateset table. |
te_tt_recno | integer | No | Foreign key referencing the corresponding template type in the tt_templatetype table. |
te_variant | varchar(32) | No | The Mosart template variant. |
te_description | varchar(128) | Yes | Optional template description. |
te_hidden | smallint | Yes | Set to true (1) if this template is to be hidden from any user presentations. |
te_name | varchar(128) | Yes | Optional template name. |
te_sendtoncs | smallint | Yes | Set to true (1) if the template implementation is to be sent to NCS. Used by some NCS only. |
