The sq_sequence table contains recorded sequences from a Viz Mosart Automation. Sequences are gallery dependent and related to the template set in use when recorded. A sequence makes it possible to record any sequence from a rundown in Viz Mosart automation for later playback.
Name | Type | Allow Null | Description |
sq_recno | integer | No | Primary key. |
sq_ga_recno | integer | No | Foreign key referencing the corresponding gallery ga_recno in the ga_gallery table. |
sq_ts_recno | integer | No | Foreign key referencing the corresponding template set ts_recno in the ts_templateset table. |
sq_name | varchar(32) | No | Name of sequence. |
sq_description | varchar(128) | Yes | Optional description of the sequence. |
sq_xml | longtext | No | The gallery specific implementation of the sequence. Stored as received from Mosart Automation in XML. |
