Installation
You install a Media Router from the Viz Mosart installer identified as
 VizMosartMediaRouter-<version number>.msi
Configuration
MMR Configuration is performed in two xml-based configuration files:
Info: The name of MediaRouterDB.xml is configurable within the Media Router service configuration.
Normally both files are placed at:
  • %ProgramData%\Mosart Medialab\ConfigurationFiles
Info: Older systems use a legacy location C:\ChannelTemplates
