The Media Router Console enables actions like:
To activate predefined salvos
To set individual crosspoints
To get router information
The following commands are available:
autofailover: Toggles Auto Failover mode. See the MosartMediaRouterService configuration.
autotake: Toggle autotake mode. See the MosartMediaRouterService configuration.
clear: Clears the Console window.
command: Syntax:
command cmd [arg1] [arg2]. Executes a Media Router command with two optional arguments. The following commands are available:backup: Enforces a backup of the Media Router database.
get <filename> : Retrieves the current Media Router database and stores the database using the given filename.
reset: Resets the Media Router to the latest Media Router database stored on the file system.
restore <filename> : Restores the Media Router database to the content of the database stored in the given filename.
flush: Flushes the current content of the Media Router to file storage. This command may be used to set the initial state of the Media Router.
deletesalvo: Syntax:
deletesalvo salvo. Deletes the specified salvo.exit: Exits the Media Router.
getconfig: Syntax:
getconfig client. Returns the current configuration for the given client. Used mainly for testing Mosart Server clients.getstatus: Returns an xml string containing current Media Router status.
help: Lists all commands.
idle: Toggles active / idle mode of the Media Router service. Used for testing.
list: Syntax:
list [salvos|clients|sources|inputs|outputs|all]. List various router information.restore: Syntax:
restore <filename>. Restores the Media Router database to the content of the database stored in the given filename.save: Syntax:
save <filename>. Retrieves the current Media Router database and stores the database using the given filename.setactive: Activates the Media Router service.
setcrosspoint: Syntax:
setcrosspoint inport outport [salvo]. Sets a crosspoint in the given salvo:If no salvo is given then the pending salvo is used. A set crosspoint request is sent to the corresponding clients.
If the given salvo is not present, a new salvo will be created.
setsalvo: Syntax:
setsalvo salvo. Fires the specified salvo.verbose: Turns on/off verbose diagnostics.
Info: When specifying crosspoints in console commands, use the inport/outport name to identify the corresponding port.
Media Router console command examples
List all current salvos:
list salvosList active connections:
list salvos currentList pending connections:
list salvos pendingList a specified salvo:
list salvos M1.AConnects video port M1.A.A to Quantel 2 / Port 1:
setcrosspoint VS.Q2.1 M1.A.VASets a crosspoint in a salvo:
setcrosspoint VS.Q2.1 M1.A.VA M1.BackupFires a salvo:
setsalvo M1.BackupDeletes a salvo:
deletesalvo M1.Backup
