The Viz Mosart User Interface may be started in several ways. Among these are
Clicking the shortcut Viz Mosart on the Desktop. (This shortcut will refer to the executable file
MosartMultiGui.exe.)Using the Windows Start menu.
Info: Advanced startup options require modifying the Desktop shortcut (or creating a new shortcut).
Creating and modifying shortcuts is beyond the scope of this guide, please consult your System Administrator or Windows documentation.
You can append the following switches to a shortcut.
Each switch is prefixed with either the / (slash ) or - (dash ) character.
Command switch | Use | Example | Comment |
browse | Start in browse mode |
| This has the same effect as activating Browse mode from the View menu. The user can later deactivate Browse mode, unless this menu option has been disabled. |
lang | Start with specific UI language |
| In addition to the default English language, a Japanese option is also available. The language may only be specified before startup and cannot be changed once the UI is in use. |
nosplash | Start without displaying the startup splash screen |
These options may be combined.
