The NRCS Plugin is the tool journalists use to add Viz Mosart template instructions to a story. Find the template you need, adjust its production details, then place it in the story either by dragging it in or with a single Add to Story action.
The plugin runs in a browser and is hosted inside the system you already work in: your newsroom computer system (ENPS, iNEWS, Octopus or OpenMedia), Viz Pilot Edge, or the Mosart web apps Showmaker, Template Editor and Smart Panel. Some controls adapt to the host, so a few of the actions described in this section are deliberately absent in some of them.
Info: For news-breaking details on the Mosart NRCS Plugin, please refer to the Mosart Web Apps Release Notes for your version of Viz Mosart at the Vizrt Documentation Center.
