The Configuration Tool enables rapid setup and management of all your Mosart Web Applications. This section presents advanced, mostly one-off configurations and references for the Mosart system administrator.
On first run, you must perform the one-time setups for the Mosart Web Apps. The quickest route is the Quick setup wizard, which walks you through the essentials. Everything it sets, and much more, remains available from the navigation sidebar.
The sidebar has four configuration entries, then a Help & Resources section, and Quick setup pinned at the bottom:
Home: the app launcher, with one card per web app. See Home below.
App Configuration: per-application settings, on five tabs in this order: NRCS Plugin, Showmaker, Template Editor, Named Overlays Editor and Smart Panel.
Server Configuration: the proxy setup method, HTTPS and certificates, sign-in, the proxy web server address, the Mosart API access key, clip labelling, and the TriCaster, Media Sequencer, Viz Arc and Pilot Data Server integrations.
Studios: defining production environments for a multi-studio site, each with its own Viz Mosart server and an optional backup.
Two further pages in this section go deeper into what Server Configuration exposes: HTTPS and Certificates, covering the proxy setup methods, the built-in certificate authority, custom certificates and their requirements; and Authentication, covering OpenID Connect sign-in and the user roles for the web apps.
Opening the Configuration Tool
The Configuration Tool is a web page served by the Mosart Web Apps server, at /configtool on the Web Apps address. On the server, the Vizrt Mosart Web Applications Configuration Tool shortcuts, on the desktop and in the Vizrt folder of the Start menu, open it in a window of its own. The window runs with administrator rights when your Windows account has them, and starting a shortcut again brings the open window forward rather than opening a second one. Apps you launch from the window open in your default browser.
When the window cannot run, the shortcuts say why, and no browser opens by itself. Without the Microsoft Edge WebView2 Runtime, a message says the tool needs it, with Download page; the Web Apps bundle installer includes the runtime. When the window fails to start, a message asks you to repair the runtime under Settings > Apps > Installed apps. With HTTPS and sign-in on, both messages also offer Open in browser, where someone with the configtool-admin role can change the settings. Starting a shortcut while the window is already open or still closing says so; try again in a moment. For a certificate this computer does not trust, see Certificate warnings below.
Upgrading to this version removes the earlier desktop Configuration Tool. The shortcuts keep their names and places, and open the new window.
Who can open it, and who can change settings
Reaching the tool: by default the tool answers only on the Web Apps server itself, and a browser on another computer is refused. To open it from other computers, turn on Serve Config Tool on the web on Server Configuration, preferably together with HTTPS and sign-in.
With sign-in off, anyone who can reach the tool can use Home, but only the Configuration Tool window on the server, run by a Windows administrator of that machine, can change settings. A browser, even one on the server, gets Home and Help & Resources only.
With sign-in on, the tool asks you to sign in like the other web apps, and changing settings needs the
configtool-adminrole. A signed-in user without it gets Home and Help & Resources (User Guide, Release Notes, API Docs and the Stream Deck Plugin download): they can launch the apps, see whether the services are up, and read the guides, but cannot change settings. The window on the server, run by an administrator, can still change settings without signing in, which is the way back in if a sign-in setting is wrong. See Authentication.
Without the right to change settings, the configuration pages, Quick setup and Mosart Server settings are dimmed, and Home says how to get that right.
Messages about the services and the settings appear in one status belt across the top of the window, on every page: a service that is down or restarting, an invalid channel templates folder, the Mosart Server out of reach, settings that could not be read, or a proxy that kept its previous configuration. Red rows are errors and yellow rows are warnings. A row offers the page whose settings fix it, Web server log and Proxy server log, and Restart service when a service is down. Most rows can be closed; a row opens again with the next check or save, or when it has something else to say. During Quick setup the belt leaves out the row about the services, the channel templates folder and the Mosart Server, because the wizard shows its own connection status.
The Configuration Tool window
Because it runs on the server, outside the Web Apps server, the window does what a browser cannot:
It opens the tool at the server's own address. With the built-in proxy, it tries the proxy's address first, then the web server address, then
localhost; with a manual proxy, the web server address, thenlocalhost.Closing the window while it is starting, stopping or taking over the service asks first, as closing then may leave the service stopped (Close anyway?, with No as the default). Going back or forward, with Alt+Left or the mouse's back button, does nothing in the window.
Opening it starts a stopped Mosart Web Applications service, and a stopped Mosart Web Proxy service when the bundled proxy is in use.
The Services and folders button in the title bar, to the left of Minimize, opens a menu with Restart Mosart Web Applications, Restart Mosart Web Proxy, Open web server log files, Open proxy server logs, Open certificate folder, Open in browser and Reload. The two restarts need administrator rights. Open in browser opens the tool in your default browser.
On the pages, a window run as administrator adds Choose file and Choose folder dialogs for the certificate, the private key and the templates folder, and a Restart service that works even when the Web Apps server does not answer. Every window adds Open folder for the built-in authority's root certificate and log links that open the log folders.
With HTTPS and a custom certificate, the window accepts the server's certificate even when this computer does not trust it, when it names another address, or when it has expired, provided it is exactly the certificate the settings name and the Mosart Web Applications service on this computer is the one answering. The status belt then warns, for example The configured security certificate is not trusted by your computer's operating system. If the certificate is not trusted, install it, or the authority that issued it, as trusted on this computer, then close the window and open it again. A certificate that names another address or has expired needs replacing; the warning stops once the new one is saved.
Any other certificate is refused, and the window shows a page of its own with the reason: not the certificate the settings name, another program answering at the web server's address (or that address is not this computer), a revoked certificate, or a web server with no certificate to serve because it cannot load the one the settings name. From there, Stop the service and change the settings opens settings-only mode, and except for a revoked certificate or none served, Open in browser shows the tool in your browser with its own certificate warning. When the window stopped the service for this and nothing has started it since, closing the window starts it again.
When the server refuses a save, a red row in the status belt reads Not saved: followed by the server's reason, such as a port already in use or a certificate that could not be loaded.
Settings-only mode
When the Mosart Web Applications service will not start, typically because of a setting, the window still opens the tool, in settings-only mode, so that you can correct it. The status belt gives the reason, with the last error the service logged, followed by Settings-only mode: change the setting that stops it and save, which starts the service. It offers Web server log, Proxy server log and Start the service, and the web apps cannot be launched meanwhile. Change the setting and save: the window starts the service and opens the tool there, on the page you saved from. Start the service starts it without a change. If the service still does not start, the window comes back to settings-only mode with the new reason. Open in browser is not available in this mode.
If even that cannot run, the window shows a page of its own: the state of both services with a Start or Restart button for each, two fixes for the settings that most often stop the server, Turn HTTPS and sign-in off and Reset the web server ports (back to 65142 and 65143), Try again, and the last lines of the web server log. Each fix keeps a copy of the settings file as it was, then starts the service.
Info: Starting services and changing settings from the window needs a Windows administrator. Only one window at a time can take the service over, for settings-only mode or one of the fixes: an administrator in another Windows session, over Remote Desktop for example, is told that another window is already working on the service.
Saving your changes
This applies to every page in this section. Save and Discard changes appear at the bottom of a page only while that page has unsaved edits. If you try to leave a page or tab with unsaved edits, a Save changes dialog offers Save, Discard or Cancel, and the move happens only once you have chosen. Most changes apply as soon as you save, with no restart: the Web Apps server reads the new settings straight away, and the bundled web proxy reloads its configuration. Three kinds of change still restart the Web Apps server: turning HTTPS on or off, turning sign-in on or off, and changing where the templates are stored (Location on the NRCS Plugin tab, or the database details while the templates are in a database). The tool restarts the server itself, showing Restarting services ... until it answers again. A save that changes the address the tool is opened on, such as turning HTTPS on or off or changing that port, reopens the tool at its new address, on the page you saved from. A save that changes the sign-in settings reloads the tool, so that you sign in again with the new settings.
Home
Home is the app launcher. Each web app gets a card showing its logo and its name, and clicking the card launches the app.
An app that ships switched off shows an ENABLE button instead of launching. The Template Editor is the one that does, and its ENABLE button takes you straight to the Template Editor tab of App Configuration. That card also carries an early-access note. Without the right to change settings, the card reads Not enabled instead.
Cards still waiting to be enabled are promoted towards the front of the list, so what needs attention is what you see first.
When more than one studio is defined, a studio strip appears at the top and the cards split into two groups, Apps for "<studio>" and Cross-studio. A single-studio installation keeps one flat list.
Quick setup
On first run the Configuration Tool opens a guided Web Apps quick setup wizard that collects the minimum needed to get the Web Apps talking to Viz Mosart. It detects the machine it is running on and pre-fills what it can.
It opens on a welcome screen offering Get started and Skip setup. The steps are:
Access (How will people reach the web apps?): the Web server address and the Browser port. The address starts as the one already saved, unless that is
localhostor another address only this machine can use; then it starts as the machine's name, which other computers can reach. The step does not acceptlocalhostor another address only this machine can use, nor an address withhttp://or a port. Activate makes this address the proxy's as well. This is also where you choose between Plain HTTP and Secure with HTTPS.Security (Certificates and sign-in): shown only when you chose Secure with HTTPS on the Access step. Offers Automatic (built-in CA) or Custom certificate, and, with a custom certificate, a Require sign-in (OpenID Connect) toggle with Issuer URL, Client ID, Secret and Scopes (optional).
Mosart server (Connect your Mosart server): a Studio name, the Mosart server address, an optional backup server address, and the API access key.
Review & activate: the screen is headed Ready to go live and reviews everything you entered, with Activate to apply it.
A rail on the left tracks your progress. You can jump back to any step you have already reached, but you cannot skip ahead, because each step is validated as you continue.
A System overview panel on the right builds up as you make each choice, showing the chain from users, through the Web Apps server, to the Mosart server.
While the settings are saved, the button reads Activating…, and Back and the steps on the rail wait. The final screen appears only once the server accepts the settings; if it refuses them, the wizard stays on Ready to go live and the status belt says why in a Not saved: row. After Activate, the final screen reports whether the apps are reachable at the address it names, headed Your web apps are live or Setup saved, but not reachable yet. Go to Home takes you into the tool and Run setup again restarts the wizard. If you chose Automatic (built-in CA), that screen also reminds you that browsers keep warning until the root certificate is trusted on client machines, and gives the root certificate's path on the server, with Open folder in the Configuration Tool window, or Copy path in a browser.
Info: You do not have to complete the wizard on first run. If you leave it, it is not forced open again the next time you start the tool, and you can re-enter it at any time from Quick setup at the bottom of the navigation sidebar.
Help & Resources
A Help & Resources section at the bottom of the navigation sidebar gathers documentation and tools:
Item | What it opens |
User Guide | This documentation, on a page inside the Configuration Tool, served at |
Release Notes | The Mosart Web Apps release notes for this version, at |
API Docs | The Mosart REST API documentation (Swagger), at |
Stream Deck Plugin | Downloads the bundled plugin file |
Mosart Server settings | The settings editor served by the Mosart server itself, so you can reach Manus Administrator settings without leaving the Configuration Tool. It opens the installation's main Viz Mosart server at that server's own address, not through the web proxy. |
Why the API documentation works through the proxy. The proxy tells the Viz Mosart server which prefix it sits behind (/mosart, or /mosart/<studio> for a studio), so the Swagger page's own try it calls go back through the Web Apps address instead of straight at the Mosart server. That is what makes the API documentation usable from a browser that can only reach the Web Apps host. /docs and /releasenotes are served by the Mosart Web Apps server itself and are reachable without signing in.
Info: The tool probes the main Viz Mosart server continuously, and the Mosart Server settings row dims for four distinct reasons, each explained on hover:
You do not have the right to change settings. The hover text reads Requires the configtool-admin role.
The settings editor is not enabled on that server. The hover text reads RCS's Manus settings editor is off: in the Remote Controller Service settings, under Web editors, turn on "Enable Manus settings editor", then restart RCS.
OIDC authentication is enabled on the Mosart server, and the settings editor has no browser sign-in. The hover text reads RCS sign-in is on, and RCS's settings editor has no browser sign-in: change the settings in Manus Administrator.
The Viz Mosart Remote Control Service is not reachable at all. Start it. The hover text reads The Mosart Server can't be reached.
If the Web Apps server does not trust the Mosart server's certificate, or the certificate does not match the Mosart server address, the row stays usable and its hover text warns: Open the Manus Administrator settings editor served by the Viz Mosart Server. Your browser may warn about its certificate: the Web Apps server doesn't trust it, or it doesn't match the Mosart Server address.
Info: With OIDC authentication enabled on the Mosart server, Mosart Server settings cannot be used from a browser. Edit the settings on the Mosart server itself instead: in Manus Administrator, type settings in the console, or in AV Automation use Devices > Settings. That is also how you edit a backup server, or any other Mosart server. The Showmaker MOS settings can still be pushed to Manus Administrator from App Configuration, in a browser signed in with an account that has the mosart-admin role.
Troubleshooting
See section Troubleshooting.
