The Prompter presents the script of the current Viz Mosart rundown as classic teleprompter text: large white type on a black background, rolling at a steady reading pace.
Info: To read a script in the Prompter, a standard Viz Mosart setup must first be running with a loaded rundown.
Opening the Prompter
  1. From the Mosart Web Apps Configuration Tool, select Home and then the Prompter card.
  2. The Prompter opens in your default web browser. On a system configured with multiple studios, it opens for the selected studio.
Until a script is available, the Prompter shows one of the following messages in the reading area:
Message
Meaning
Connecting to Mosart…
The Prompter is establishing its connection to the Viz Mosart server.
Waiting for the Mosart Server
The connection is up, but no live timing is arriving from Viz Mosart. Check that Manus Administrator is running.
No rundown loaded
Load a rundown in Viz Mosart and it appears in the Prompter automatically.
A connection chip in the top right corner of the screen shows the live connection state at all times: Connecting…, No Mosart Server, or Connected.
The Prompter View
The whole rundown renders as one continuous script, in running order. What the reading area shows depends on whether the Prompter is following the live item or being browsed.
The view keeps itself up to date: stories and script added, edited, deleted or reordered elsewhere (in Showmaker or in the newsroom system) appear in the Prompter automatically, without reloading the page.
While Following the Live Item
During normal on-air operation the reading area is kept as clear as possible, so nothing but script passes through the cue line:
  • The in-flow story headers and item labels fade out, so they never roll up through the reading area and distract the talent.
  • Instead, a fixed banner at the top of the screen carries that context: the on-air story and item, so the presenter always knows what is live. Items with nothing to read are tagged No script in the banner.
  • The state strip stays visible in the top left corner, with the on-air timers just below it. Both are described below.
While Browsing
The moment the operator scrolls or steps away from the on-air item, the full structure of the rundown reappears:
  • Every story appears as a numbered header showing its name, and its planned duration when one is set. The on-air story's header also shows a live countdown to the next story.
  • Each item in a story is labelled with its Mosart template (for example, a camera or package name) in the template type color, together with the item's planned duration when one is set. Items with script show their script below the label; items with no script show the label only.
In both states, a thin progress bar along the bottom edge of the screen shows the reading position within the whole rundown, and the name of the loaded rundown appears in the top right corner while the control bar is visible.
Story headers of rundowns created in Showmaker also offer an Edit in Showmaker button, which opens that story in Showmaker in a new browser tab. Like the control bar, it is only shown while the controls are visible, so it disappears once they auto-hide.
State Strip
Once a rundown is loaded, a compact state strip stays visible in the top left corner of the screen and shows two words. It is deliberately exempt from the control bar auto-hide, so the operator can always read the transport and follow state without touching anything. It is hidden in the connecting and empty states, where a transport word would be misleading, and in display-only mode.
State
Meaning
RUNNING
The script is rolling.
WAITING
The roll is running but held at the end of the on-air item's script, waiting for the next take. Shown only while Follow the rundown is on.
PAUSED
The script is not rolling.
HOLD
A rundown is loaded but the Viz Mosart timeline is not running (a programme hold).
FOLLOWING
The Prompter is tracking the on-air item.
PREVIEW
Follow is on, but the operator has scrolled away from the on-air item. Highlighted as a warning; a Jump to live button is offered.
MANUAL
Follow the rundown is switched off; the operator drives the scroll. Highlighted as a warning.
Timers
While Follow the rundown is on and the on-air item is found in the loaded rundown, an elapsed timer sits below the state strip in the top left corner, counting up to show how long the on-air item has been live.
A second timer joins it only while an item with no script is on air. It counts down to the moment the next scripted item is due to roll, adding together the time left on the on-air item and the planned durations of any further no-script items ahead of it, so a run of back-to-back packages reads as one shrinking number. If the on-air item runs long, the countdown crosses zero and turns red to show that the next script is overdue.
Following the On-Air Rundown
With Follow the rundown switched on (the default), the Prompter follows the production automatically, item by item:
  • When a rundown is taken on air, scrolling starts automatically; nobody has to press play.
  • Taking an item that has script brings that item's script to the cue line and rolls it at the reading pace. The roll holds when the last line of the item's script reaches the cue line, so the Prompter never rolls ahead of what is on air. While it holds, the state strip reads WAITING.
  • Taking the same item again (a re-take) re-anchors its script to the cue line and rolls it again from the top.
  • A take always restarts the roll, even after a manual pause. A manual pause holds only between takes.
Reading Ahead over Items with No Script
When an item with no script is taken on air (a package, a full-screen graphic, a break, a live source), there is nothing for the talent to read, so the roll stops. What happens next depends on the Read ahead during no-script items setting (default on):
  • On: The Prompter brings the next scripted item in the rundown to the cue line so the presenter can read ahead. The reading cue turns amber, band and arrows alike, to signal that the script on the cue line is not yet on air, and the countdown timer shows when it is expected to roll. The moment that item is taken, it rolls from where it already sits.
  • Off: The Prompter freezes in place until the next scripted item is taken. The reading cue still turns amber and the countdown timer still shows when the next script is due, so it stays clear that nothing on the cue line is on air.
In both cases the on-air banner keeps showing the live story and item, tagged No script.
Browsing While On Air
Scrolling by hand (mouse wheel, touch drag, Home, or stepping between items) while Follow is on switches the Prompter to PREVIEW: the roll stops so the operator can read anywhere in the rundown without being pulled back. To return:
  • Select Jump to live (or press L) to snap back to the on-air item and resume following.
  • Or simply wait: the next take automatically returns the Prompter to the live item.
On a touch screen, a stationary tap only reveals the controls. It takes a real drag to switch to PREVIEW, so touching the glass cannot knock the Prompter off air mid-read.
While following, if the on-air item is not present in the loaded rundown (for example it was removed after the rundown was loaded), the Prompter stops the roll and shows the warning On-air item is not in the rundown rather than rolling stale script.
The Control Bar
A floating control bar at the bottom of the screen keeps the essential controls within reach. It hides after four seconds without input and reappears on any mouse movement, touch, or Prompter shortcut key. It also stays put while the settings panel or the Help menu is open.
Control
Description
Settings
The gear button opens the settings panel (see below).
Scroll speed
A slider from 0.25× to 6× with a numeric readout. It moves in quarter steps up to 2× and in half steps from 2× to 6×, so the everyday range keeps fine control. The speed is a constant reading pace: the roll advances relative to the text size, so the talent reads the same number of lines per minute at any text size. At the default text size, 1× approximates a typical news reading pace.
Start/pause scrolling
The round button in the center of the bar starts and pauses the roll (also the Space key).
Text size
A slider from 24 pt to 96 pt in 3 pt steps, with a readout in points.
Help
Opens a menu offering Keyboard shortcuts, Give feedback and About. The Documentation and What's new entries are listed but not yet selectable.
The speed and text size controls, the play button and the reading cue are all hidden while one of the messages above is shown, since there is no script to drive.
Settings
The gear button on the control bar opens the full settings panel. Every setting takes effect immediately and is remembered by the browser on that machine, so each prompter position keeps its own setup.
Group
Setting
Description
Text & display
Font
The typeface for the script text (default Open Sans). The list offers common fonts found on the machine; Show all installed fonts expands it to every installed font (requires a browser permission; available in Chromium-based browsers such as Chrome and Edge).
Text & display
Text size
The script text size, 24 pt to 96 pt in 3 pt steps (default 42 pt). The same setting as on the control bar.
Text & display
Margins
Extra horizontal margins around the script, 0 to 20 percent of the screen width (default 3 percent).
Text & display
Mirror horizontally
Flips the output left-to-right for teleprompter glass rigs.
Text & display
Mirror vertically
Flips the output top-to-bottom.
Scrolling
Speed
The reading pace, 0.25× to 6× (default 1×): quarter steps up to 2×, then half steps up to 6×. The same setting as on the control bar.
Scrolling
Follow the rundown
Tracks the on-air item and rolls its script automatically (default on). Off hands full manual control to the operator.
Scrolling
While an item with no script is on air, brings the next scripted item to the cue line so the talent can read ahead (default on). Shown only while Follow the rundown is on.
Cue indicator
Off / Left / Right / Both
Where the cue arrows appear: on the left edge, the right edge, both edges, or not at all (default Both). Off hides the entire cue indicator, band included.
Cue indicator
Highlight band
Shows or hides the translucent highlight band across the script, independently of the arrows (default on). Not shown while the cue indicator is Off.
Cue indicator
Position
The vertical position of the cue line, 25 to 75 percent from the top of the screen, in 5 percent steps (default 25 percent).
The Reading Cue
The reading cue marks the line the talent should be reading. It consists of two parts:
  • Cue arrows at the left and/or right edge of the screen, per the Cue indicator setting.
  • An optional translucent highlight band across the full width of the script.
When following the rundown, each item taken on air aligns its script to the cue line, and the auto-roll keeps the current text passing through it. The cue's vertical position is adjustable in the settings.
Some talent find the full-width band distracting at large studio text sizes. The Highlight band setting turns the band off while keeping the arrows, matching the arrow-only cue of traditional prompters. Setting the cue indicator to Off hides everything, band and arrows alike.
While the Prompter is reading ahead over an item with no script, the band and the arrows turn amber as a reminder that the text on the cue line is not yet on air.
Manual Transport
For rehearsal, or whenever the operator wants full control of the pace, switch Follow the rundown off (the F key). The state strip reads MANUAL and the Prompter no longer reacts to takes; the script moves only when the operator drives it:
  • Start and pause the roll with the play button or Space.
  • Adjust the pace with the speed slider or the Up and Down arrow keys. Each press moves one step on the same scale as the slider.
  • Change the text size with the slider or the + and − keys.
  • Step to the previous or next item with Page Up and Page Down.
  • Scroll freely with the mouse wheel or by touch; press Home to return to the top.
The scroll controls also work while Follow is on, and switch the Prompter to PREVIEW until the next take or a Jump to live: the mouse wheel, a touch drag, Home, and stepping between items. Play, pause, speed and text size also work, but they do not switch to PREVIEW: the Prompter keeps following, and the next take restarts the roll.
Info: The Prompter uses the operating system's Reduce Motion accessibility setting. With it on, jumps between items are made instantly instead of being smooth-scrolled. The reading roll itself is unaffected.
Keyboard Shortcuts
Press K (or select Help > Keyboard shortcuts) to show this list in the app.
Command
Keys
Start / pause scrolling
Space
Faster / slower
Larger / smaller text
Follow the rundown
F
Jump to live
L
Previous / next item
Page Up / Page Down
Mirror horizontally
H
Mirror vertically
V
Cue indicator
C
Scroll to top
Home
Keyboard shortcuts
K
The plus and minus keys work on both the main keyboard and the numeric keypad. Shortcuts do not fire while the keyboard focus is inside a control, a menu or a dialog, so the focused control keeps its own key handling; and the transport keys stay inactive until a rundown is loaded.
Remote Control from Smart Panel
The Prompter can be driven from a Smart Panel:
  • A panel button with the Prompter Play/Pause action starts and pauses the roll. The play/pause state is shared, so every open Prompter window starts and stops together.
  • The Prompter widget embeds the live prompter output in a panel, script only with no controls, for confidence monitoring alongside other panel items.
Display preferences (font, text size, mirroring, the cue indicator) remain local to each Prompter window and are not affected by remote control.
Tip: To add buttons and widgets to a panel, see the Smart Panel section of this guide.
Session and Sign-in
This applies only where authentication (OIDC) is enabled for Mosart Web Apps. With authentication off, the Prompter never asks anyone to sign in.
The Prompter is an on-air surface, so it holds its sign-in for as long as its page is open. It is never signed out for inactivity, and nobody has to touch the glass to keep it alive. A prompter left running unattended through a show stays signed in.
The one case where a session can still end is one that could not be held: the Mosart Web Apps host was unreachable for a long stretch, or the machine was switched off, or the page was reloaded after the session had already gone. The Prompter then shows a Session timeout! dialog with a Login button, and script stops updating until somebody signs in again.
Note: The session dialogs are the one thing display-only mode does not hide. Where authentication is enabled, an expired session shows its dialog even on a passive screen or inside an embedded Smart Panel prompter widget, so the display reports that it needs signing in again rather than sitting silently on stale script.
Your administrator can change this and let the Prompter time out when idle, though it is not recommended for an on-air position. See Setup and Administration of Prompter.
