The main menu at the top of the main window provides easy access to functions and workflows:
A brief description of the main menu sections is listed below. For certain menu items, a more detailed explanation can be found later in this chapter.
File
Option
Function
Open Show...
Show a directory panel to open a TrioShow.
Open External Playlist...
Show a directory panel to open an external playlist.
New Page View...
Add a new pageview.
New Show Playlist...
Add a new playlist.
Configuration
Show the Configuration window where you configure Viz Trio.
Show Properties
View and configure properties for a TrioShow.
Import Viz Engine Archive...
Import Viz Engine Archive (.via) files from disk and re-import any affected templates in the current show.
Import Show Archive...
Import a TrioShow(.trioshow file) from disk.
Export Show Archive...
Export Show to disk as .trioshow file.
Export Selected Pages Archive...
Export Show with only selected pages including associated items, see Export Selected Pages Archive.
Slave Mode
Set Viz Trio in Slave Mode, see Slave Mode.
Quit
Quit Viz Trio.
Page
Option
Function
Save
Save the current page you're working on.
Save As...
Save the current page you're working on with a new name.
Rename...
Rename the current page you're working on.
Change Template...
Change the template for a page.
Refresh Linked Data
Asynchronously refresh the data for a page linked to a feed.
Reimport
Reimport the template design for a page.
Delete
Delete the currently selected page. You are asked for confirmation.
Delete All
Delete all pages. You'll be asked to confirm.
Save to XML...
Save page to an XML-file on disk.
Load from XML...
Load page from an XML-file on disk.
Print/Save Snapshot...
Take a Snapshot, which can be printed or saved to disk.
Move to Number...
Move page to a specific number.
Move with Offset...
Move page with offset.
Copy to Number...
Copy page to a specific number.
Copy with Offset...
Copy page with offset.
Playout
Option
Function
Take
Performs a direct take on the selected page.
Pause
Pauses the current element.
Continue
Continues the animation on the selected page, or any page that is loaded in the same transition logic layer as the selected page.
Out
Takes out the selected page, or any page that is loaded in the same transition logic layer as the selected page. Hard cut.
Cue
Prepares the clip for playout so the first frame is ready in the player.
Cue Append
Prepares the clip for playout. The clip starts automatically when the current clip ends.
Take and Read Next
Takes the current element and reads the next one.
Cleanup Channels
Cleans up the renderers (Viz Engines) currently in use by the open show. Asks for confirmation. This frees up renderer memory and real-time capacity. See Cleanup Channels.
Initialize Show on Channels
Loads the selected show on the program and preview renderers. See Initialize Channels.
Initialize Show on Local Preview
Loads the selected show on the Preview renderers. See Initialize Channels.
Update on Program
Updates on Program renderer without reloading or rerunning animations. Only for Transition Logic scenes.
Update on External Preview
Updates on External Preview renderer without reloading or rerunning animations. Only for Transition Logic scenes.
Clear Program
Takes out the scene on Program renderer, but does not clean up the renderer (scenes remain in memory).
Clear external Preview
Takes out the scene on Preview renderer, but does not clean up the renderer (scenes remain in memory).
Start Scroll
See Scroll Control.
Stop Scroll
See Scroll Control.
Continue Scroll
See Scroll Control.
Arm Current
See Arm and Fire.
Arm Selected
See Arm and Fire.
Unarm Current
See Arm and Fire.
Unarm All
See Arm and Fire.
Fire All
See Arm and Fire.
View
Option
Function
Expert Mode
Toggle. Enable Viz Trio to operate in expert mode. Works in conjunction with “Show Only in Expert Mode” from the Control Plugin options.
Tabfields
Toggle. Enable tabfields.
Commands
Show the command window. In this window you can execute Viz Trio macros and commands using a command-line (cli) interface.
Errors
Show the error message window.
Running Carousels
Show the task window where all running tasks in the active profile are displayed.
Refresh Thumbnails
Force refresh of all thumbnails.
Restore Default Layout
Stacks and docks the main windows (Templates, Page List and Tab Fields) and cascades all other window in undocked mode.
Lock Layout
Prevents accidental undocking of window. It is still possible to resize and dock floating windows.
Tools
Option
Function
Switch to Viz Artist. Viz Trio keeps running. While in Artist, click the Viz Trio button to return to Viz Trio again. See Viz Artist Mode.
TimeCode Monitor
Start the TimeCode Monitor. See TimeCode Monitor.
Datacenter
Start the Datacenter application if installed on localhost. See Datacenter in Viz Trio.
Help
Option
Function
View Help
Show help and documentation.
Legal Notices
Information about third-party code libraries.
Trio Licensing
Opens the Viz Trio license dialog box.
About...
Displays which Viz Trio version and build that has been installed on your machine (essential information to attach when reporting issues to Vizrt), Credits and Legal Notices.
