This is the user guide for Viz World Classic (previously known as Viz Curious Maps). It is designed to fit people with no or little experience in using the Viz World Client and Server. The purpose of this document is to help new users become familiar with the client; to illustrate the client’s editor, and to show the available options.
This guide provides reference information about the program’s more advanced features. These include selecting map details, working with style sheets, importing and working with street data, adding text and graphics, creating drawings from vector shapes, adding effects with lighting and effects, and controlling animation.
Document Structure
Title
Content
Quick Tour
Provides a complete introduction to using Viz World Classic on the PC, and is the recommended starting point for anyone learning to use the program. It provides a series of short worked examples, each of which takes you on a quick guided tour of the program’s key features to show what it can achieve and help you become familiar with the user interface.
Working with Maps
Explains the options for creating and working with map layers, including using the Properties panel to define the projection, and using the Contents panel to select countries and places for incorporation into the map.
Working with Styles
Explains how to use the style sheets to make it easy to set up a series of house styles, and convert projects between house styles with a single click. It also explains how style sheets help to establish consistency across projects, or between designers.
Reusing Design Elements
Explains how you can easily reuse styles, layers, and colors created in earlier projects and gives recommended techniques for setting up and sharing style sheets, templates, and projects between users.
Working with Street Maps
Explains how to import street data and draw it on your maps to create maps from the whole world, down to a single street corner or building.
Adding Text to a Project
Explains how to incorporate text into projects, and describes how to control the appearance of the text and the way it is animated.
Working with Images and Movies
Explains how to incorporate bitmap images and movies into animations, and describes the controls available for altering their appearance, and controlling the way they are animated.
Working with Shapes
Explains how to add drawings to a map by creating vector shapes, either using separate shape layers or by adding shape details to map layers. It also explains how you can create and edit shapes, and change their appearance to achieve exactly the effect you want.
Working with ESRI Shape Files
Describes how to import map data in ESRI Shape File Format, and configure it for use with Viz World Classic.
Lighting and Effects
Explains how to use the lighting and effects features, to enable you to add shading and depth to your map animations and give them a unique and distinctive appearance.
Controlling Animation
Explains how to use the time slider to control the progress of an animation. It also describes how to use the tool to set up impressive animations with a few simple clicks, and the Keybars panel to provide individual control over each component of a project.
Rendering a Project
Explains how to render your animation as a preview, or as a finished movie. It also describes the options for exporting an image or a 3D model from a project.
Related Documents
For complementary information, see the following documents:
  • Viz Artist User Guide: Information on how to create graphics scenes in Viz Artist.
  • Viz World User Guide: Information on how to use Viz World Client and Server to setup a map server solution and build map template graphics for newsroom and control room systems.
For more information about all of the Vizrt products, visit:
Feedback and Suggestions
We encourage suggestions and feedback about our products and documentation. To give feedback and/or suggestions, please contact your local Vizrt customer support team at www.vizrt.com.
Copyright ©2025 Vizrt. All rights reserved.
Disclaimer
Antivirus Considerations
Technical Support
