The License Portal enables customers to manage licenses, using WIBU Systems. This documentation guides you through the different options and processes.
Improvements and Bug Fixes
Kindly check the Vizrt Licensing Release Notes for the latest changes.
This software protection program is implemented in Vizrt software as part of major new releases. Prior versions covered by software protection can continue to run on the node-locked licensing.
Feedback and Suggestions
Support
Legal
Copyright ©2025 Vizrt. All rights reserved.
Disclaimer
Antivirus Considerations
Real-Time Scanning: Keep it enabled, but exclude any performance-sensitive operations involving Vizrt-specific folders, files, and processes. For example:
C:\Program Files\[Product Name]
C:\ProgramData\[Product Name]
Any custom directory where [Product Name] stores data, and any specific process related to [Product Name].
Risk Acknowledgment: Excluding certain folders/processes may improve performance, but also create an attack vector.
Scan Scheduling: Run full system scans during off-peak hours.
False Positives: If behavior-based detection flags a false positive, mark that executable as a trusted application.
Technical Support
For technical support and the latest news of upgrades, documentation, and related products, visit the Vizrt web site at www.vizrt.com.
