The metagraphics workflow is available for the Avid and Adobe platforms:
  • Avid lets you export sequences with metagraphics (for Windows only, as Avid Assistant is for Windows only).
  • For Adobe, both import and export metagraphics is available (for Windows and Mac).
Avid Media Composer
Exporting Metagraphics
For a Vizrt graphics effect to to be exported as a metagraphic, the following checkbox must be checked in the Vizrt Graphics Plugin effect:
If this checkbox is unchecked, the normal workflow of graphics burn-in is used.
Info: For more information about the metagraphics workflow, see the Exporting Metagraphics section of the Graphics Plugin User Guide.
Note: Exporting sequences with metagraphics is only available if Avid Assistant is installed.
Previewing Metagraphics
You can enable a static preview when metagraphics is enabled, which saves resources.
  1. Click on Config to access the Configuration Tool.
  2. Click the Advanced tab and in Settings view select Avid settings.
  3. Check the Still image playback metagraphics checkbox.
Info: For more information about still image playback, see the Adobe/Avid/Edius Settings section in the Graphics Plugin User Guide.
Adobe Premiere
For Adobe Premiere, metagraphics are configured in Adobe Assistant. See the Adobe Assistant documentation for more information.
