Pilot Data Server Administrator Guide
Version PDS-8.6 | Published January 29, 2021 ©
Change Notifications
Change notifications are available through the REST API and the STOMP protocol on the Pilot Data Server.
REST API
A list of database changes ordered from most recent to oldest:
  • Located at http://pdshost:8177/changelog
  • Parameters:
    • startId: The ID of the least recent change, or -1 for no limit. Default is -1.
    • lastKnownId: The ID of the most recent change, or -1 for no limit. Default is -1.
STOMP API
In a Viz Pilot system, the text-based message Streaming Text Oriented Messaging Protocol (STOMP) is used to subscribe to change notifications from Graphic Hub REST and Pilot Data Server. STOMP provides push notifications of new changes.
  • Located at: stomp://pdshost:9876/?destination=/changelog&lastKnownId=-1
  • Parameters:
    • lastKnownId: Mandatory, should be the ID in the STOMP link that is provided by the REST API. For example, when the data stored in the Pilot database changes, a message is delivered to all of the STOMP clients that are subscribed to the server.
Note: The default change notification port for the STOMP protocol is 9876. Other services using this port may suppress the change notifications.
