Preview Server Administrator Guide
Version 4.3 | Published June 26, 2019 ©
Troubleshooting
This section covers issues that may arise while installing, configuring or using the Preview Server.
If you do not find answers to your issues, please contact your local Vizrt representative at https://www.vizrt.com/support.
Troubleshooting Tips
Services do not start after installing the latest Preview Server
  • Machines with Apple's Bonjour installed sometimes refuse to install the Preview Server. Uninstalling Bonjour may resolve this installation issue.
Known Limitations
  • It is possible to add the same renderer multiple times on the Preview Server Home page if using different spellings. For example, a renderer can be added by entering its hostname, and then, if entering the IP address, the renderer will be added again. Adding the same renderer twice will produce incorrect snapshots.
  • Snapshots of scenes with no key defined will result in empty images.
  • Adding video mode Viz Engines as renderers could produce incorrect results in scenes using ControlVideo.
  • Preview Server Release Notes
