Tracking Hub Command Interface
Version 1.4 | Published October 30, 2020 ©
Communication with Viz Tracking Hub
The TH provides a command interface similar to that offered by Viz Engine. The default port is 20000.
Command Syntax
<token> <location>[*<property>]* <command> [<parameter>]*
Where:
  • <token>: The token tells the receiver how to interpret the message, if an answer is expected etc.
  • <location>: Reference to an object or a collection of objects.
  • <property>: Reference property or properties or member objects contained in the root object or collection.
  • <command>: The command to be executed on the property or object.
  • <parameter>: Command parameter or parameters.
Tokens
> 0
Client will receive and answer carrying the same token.
-1
Client will receive no answer.
-2
(only for message from TH) Reserved for notifications.
-3
(only for message from TH) Status message.
Answer
You always get a string as an answer. It starts with a status code followed by the actual content (e.g. XML) or an error message.
(0|1) [string|xml|message]
0
Failure
Followed by an optional error message.
1
Success
Followed by an optional status message or an answer in a prearranged format.
Long Pattern for Answer Handling
if (answer != null) {
    // Handle error answer
    if (CommandMessage.IsFailure(answer)) {
        if (CommandMessage.IsErrorMessage(answer)) {
            Log.Error("{0} returned an error: {1}", command, CommandMessage.ExtractMessage(answer));
            return;
    // Handle success answer
    if (CommandMessage.IsSuccess(answer)) {
        // HANDLE VALID ANSWER HERE
        return;
    Log.Error("{0} returned an invalid answer", command);
} else {
    // No answer at all
    Log.Error("{0} returned no answer", command);
This pattern is implemented in: CommandMessage.IsSuccess(string answer, string command)
Short Pattern for Answer Handling
    // REPORT ERROR HERE
    return; // then bail out
Failure Messages
Note: Any command message may fail and return an error. It is because of the command interface having changed with a new version of Tracking Hub.
The most common generic error messages are:
Unknown Location
0 Unknown location: <location>
Returned if the top level location of the command message is unknown.
Unknown Property
0 Unknown property: <location>[*<property>]*
Returned if command message starts with a known location, but contains an unknown property in the following property path.
Unknown Command
0 Unknown command: <location>[*<property>]* <command>
Returned if command message starts with a known location and valid property path, but ends on an unknown command.
Commands
MAIN
Tracking Hub matching, available ports, IPs, etc. (MAIN*):
MAIN*COMPORTS GET = <portname>[,<portname>]*
MAIN*PARAMETERLIST GET = <parametername>[,<parametername>]*
MAIN*PROTOCOLS GET = <protocolname>[,<protocolname>]*
MAIN*LOCAL_IPS GET = <ip>[,<ip>]*
MAIN*VIZ_IP SET <ip> or <adaptername>
GET = <adaptername>
MAIN*TRACKING_IP SET <ip> or <adaptername>
GET = <adaptername>
MAIN*CONFIGURATIONS GET = [<name>[,<name>]*]?
//MAIN START not used
//MAIN STOP  not used
//MAIN*RUNNING GET = <bool> not used
MAIN*WRITE_LOG_FILE SET <bool>
GET = <bool>
MAIN*FORWARD_LOG SET <bool>
GET = <bool>
MAIN*LICENSE SET <key>
GET = <name>,<number of cameras>,<days left> (name is either Cameras or Dongle, -1 means unlimited cameras/days)
MAIN*DEBUGLEVEL SET <int>   (range is  1 ... 10, 1 only emergency, 10 all)
GET = <int>
MAIN*DEBUGLEVEL++
MAIN*DEBUGLEVEL--
CONFIG
Store configuration on the Tracking Hub machine:
CONFIG EXISTS = 0|1
CONFIG SAVE
CONFIG LOAD
CONFIG SET = <name>
CONFIG GET = <name>
CONFIG RESET
CONFIG*BASE SAVE
CONFIG*BASE DISMISS
STUDIO
Base studio configuration (STUDIO*):
STUDIO GET = <xml>
STUDIO*MODE SET FREE|AV|VIZ
GET = SET
STUDIO*FREQUENCY SET 50|60|59.94
GET = SET
STUDIO*SHAPE SET LSHAPE_LEFT|LSHAPE_RIGHT|USHAPE|WALL|HOLE
GET = SET
STUDIO*CYC SET <xml>
GET = SET
STUDIO*TIMING GET = <bool>
STUDIO*SENDDELAY GET = <int> [in ms]
SET   <int> [in ms]
STUDIO*BUSYLOOP  GET = <int> [type]
SET   <int> [type]
TEMPLATES
Templates stored on the Tracking Hub machine (TEMPLATES*):
TEMPLATES*COUNT GET = <amount of templates>
TEMPLATES LIST = <name1, name2, . . .>
TEMPLATES*<name> GET = <xml>
TEMPLATES*<name> SET <xml>
TEMPLATES*<name> DELETE
TEMPLATES*<name> LOAD = <xml>
TEMPLATES*<name> USE <name>
TEMPLATES*<name> SAVE <ts_name1 ts_name2 . . . rig_name1 rig_name2 . . . 1 2>
TRACKING SYSTEMS
Tracking Systems set up on the Tracking Hub machine (TRACKING_SYSTEMS*)
TRACKING_SYSTEMS*COUNT GET = <number of tracking systems>
TRACKING_SYSTEMS CREATE <name>
TRACKING_SYSTEMS DELETE <name>
TRACKING_SYSTEMS XMLFILES GET = <string>
TRACKING_SYSTEMS*<idx/name> GET = <xml>
TRACKING_SYSTEMS*<idx/name> CONNECT
TRACKING_SYSTEMS*<idx/name> DISCONNECT
TRACKING_SYSTEMS*<idx/name>*INDEX GET = <index>
TRACKING_SYSTEMS*<idx/name>*NAME SET <name>
GET = <name>
TRACKING_SYSTEMS*<idx/name>*SLOTINDEX SET <slotindex>
GET = <slotindex>
TRACKING_SYSTEMS*<idx/name>*PROTOCOL SET <protocolname>
TRACKING_SYSTEMS*<idx/name>*NETUSE SET <netuse>
GET = <netuse>
TRACKING_SYSTEMS*<idx/name>*COMPORT SET <name>
GET = <name>
TRACKING_SYSTEMS*<idx/name>*BAUDRATE SET <baud>
GET = <baud>
TRACKING_SYSTEMS*<idx/name>*PARITY SET <baud>
GET = <baud>
TRACKING_SYSTEMS*<idx/name>*STOPBITS SET <baud>
GET = <baud>
TRACKING_SYSTEMS*<idx/name>*DATASIZE SET <baud>
GET = <baud>
TRACKING_SYSTEMS*<idx/name>*HOST SET <ip>
GET = <ip>
TRACKING_SYSTEMS*<idx/name>*PORT SET <port>
GET = <port>
TRACKING_SYSTEMS*<idx/name>*XMLFILE SET <string>
GET = <string>
TRACKING_SYSTEMS*<idx/name>*STATUS GET = DISCONNECTED|NOT_RECEIVING|BAD_TIMING|GOOD_TIMING
//only in running mode
TRACKING_SYSTEMS*<idx/name>*PARAMETERS GET = <parametername>[,<parametername>]*
TRACKING_SYSTEMS*<idx/name>*SENDRAWDATA SET <bool>
TRACKING_SYSTEMS*<idx/name>*RAWDATA_OFFSET <parametername> ACT
TRACKING_SYSTEMS*<idx/name>*RAWDATA_OFFSET <parametername> SET <int>
// not in use any longer
//TRACKING_SYSTEMS*<idx/name>*SENDDELAY GET = <ms>
//                                      SET <ms>
//this command switches hexdumplogging
TRACKING_SYSTEMS*<idx/name>*HEXLOG SET <bool>
GET = <bool>
TRACKING_SYSTEMS*<idx/name>*TICKCOUNT SET <parametername, value>[,<parametername, value>]
GET = <parametername, value>[,<parametername, value>]
TRACKING_SYSTEMS*<idx/name>*RCVTIMECORR SET <bool>
GET = <bool>
LATTICES
Lattices set up on the Tracking Hub machine (LATTICES*):
LATTICES*COUNT GET = <zero-based index>
LATTICES CREATE <name>
LATTICES DELETE <name>
LATTICES LENSFILES GET = <string>
LATTICES LENSFILES RELOAD
LATTICES*<idx/name> CREATE PARENT|CHILD <childname>
LATTICES*<idx/name> GET = <xml>
LATTICES*<idx/name>*INDEX GET = <index>
LATTICES*<idx/name>*NAME SET <string>
GET = <string>
LATTICES*<idx/name>*FILTER_ZOOM SET <bool>
GET = <bool>
LATTICES*<idx/name>*TYPE SET SIMPLE_CAM|OBJECT|LATTICE
GET = SIMPLE_CAM|OBJECT|LATTICE
LATTICES*<idx/name>*SLOTINDEX SET <slotindex>
GET = <slotindex>
LATTICES*<idx/name>*<parameter>*NAME SET <string>
GET = <string>
                               *OFFSET SET <float>
GET = <float>
                               *INVERT SET <bool>
                                     GET <bool>
                               *DELAY SET <float>
                                      GET <float>
LATTICES*<idx/name>*TRACKINGDELAY SET <frames(float)>
LATTICES*<idx/name>*VISUAL_XML SET <xml>
                               GET = <xml>
LATTICES*<idx/name>*CALIBRATION SET <bool>
                                GET = <bool>
LATTICES*<idx/name>*CALIBRATIONDONE GET = <bool>
LATTICES*<idx/name>*CALIBRATION_RANGE GET = <zoom_min> <zoom_max> <zoom> <focus_min> <focus_max> <focus>
LATTICES*<idx/name>*LENSRANGE SET <lensrange_min> <lensrange_max>
                              GET = <lensrange_min> <lensrange_max>
LATTICES*<idx/name>*SCALEVAUES SET <ScXNear, ScXWide, ScYNear, ScYWide>
                               GET = <ScXNear, ScXWide, ScYNear, ScYWide>
LATTICES*<idx/name>* LENSFILE SET <string>
                              GET = <string>
LATTICES*<idx/name>* LENSFILE_LENSEXT SET <string>
                                      GET = <string>
SERVICES
Services set up on the Tracking Hub machine (SERVICES*):
SERVICES*COUNT GET = <zero-based index>
SERVICES*BY_INDEX*<idx> GET = <xml>
                        START
                        STOP
SERVICES*BY_INDEX*<idx>*SLOTINDEX GET = <slotindex>
                                  SET <slotindex>
SERVICES*BY_INDEX*<idx>*RUNNING GET = <bool>
SERVICES*BY_ID*<service_id> GET = <xml>
                            START
                            STOP
SERVICES*BY_ID*<service_id>*SLOTINDEX GET = <slotindex>
                                      SET <slotindex>
SERVICES*BY_ID*<service_id>*RUNNING GET = <bool>
SERVICES ADD PARAMETER ALL                         <ip> <port> = <service_id>
SERVICES ADD PARAMETER             <lattice_name>  <ip> <port> = <service_id>
SERVICES ADD TRACKING_TIMING       <ts_name>       <ip> <port> = <service_id>
SERVICES ADD COMMUNICATION_TIMING  <service_id>    <ip> <port> = <service_id>
SERVICES ADD CAMERA                <lattice_name>  <ip> <port> <cameranumber> = <service_id>
SERVICES ADD OBJECT                <lattice_name>  <ip> <port> = <service_id>
SERVICES ADD TIMECODE              <timcode>       <ip> <port> = <service_id>
SERVICES REPLACE <service_id> (TRACKING_TIMING|COMMUNICATION_TIMING) (<ts_name>|<service_id>)    <ip> <port>                = <service_id>
SERVICES REPLACE <service_id> (PARAMETER|OBJECT|TIMCODE)             (<lattice_name>|<timcode>)  <ip> <port>                = <service_id>
SERVICES REPLACE <service_id> CAMERA                                  <lattice_name>             <ip> <port> <cameranumber> = <service_id>
SERVICES REMOVE <service_id>
SERVICES REMOVE_ADDR <ip>
SERVICES REMOVE_ALL
ROUTERS
Configure routers controlled by VizTH (ROUTERS*):
List Available Router Models
ROUTERS*MODEL_LIST GET = <model>[,<model>]*
Manage Routers
ROUTERS ADD <model> <name> = <index>
ROUTERS REMOVE <name> | <index>
ROUTERS*COUNT GET = <count>
Configure Individual Routers
ROUTERS*<idx/name> GET = <xml>
ROUTERS*<idx/name>*INDEX GET = <index>
ROUTERS*<idx/name>*NAME SET <string>
                        GET = <string>
ROUTERS*<idx/name>*MODEL SET <model>
                         GET = <model>
ROUTERS*<idx/name>*AB_MODE SET <mode>
                           GET = <mode>
ROUTERS*<idx/name>*NETUSE SET <netuse>
                          GET = <netuse>
ROUTERS*<idx/name>*COMPORT SET <name>
                           GET = <name>
ROUTERS*<idx/name>*BAUDRATE SET <baud>
                            GET = <baud>
ROUTERS*<idx/name>*PARITY SET <baud>
                          GET = <baud>
ROUTERS*<idx/name>*STOPBITS SET <baud>
                            GET = <baud>
ROUTERS*<idx/name>*DATASIZE SET <baud>
                            GET = <baud>
ROUTERS*<idx/name>*HOST SET <ip>
                        GET = <ip>
ROUTERS*<idx/name>*PORT SET <port>
                        GET = <port>
ROUTERS*<idx/name> CONNECT
ROUTERS*<idx/name> DISCONNECT
ROUTERS*<idx/name>*CONNECTED GET = <boolean>
ROUTERS*<idx/name>*INPUTS*<idx>*NAME SET <string>
                                     GET = <string>
ROUTERS*<idx/name>*OUTPUTS*<idx>*NAME SET <string>
                                      GET = <string>
ROUTERS*<idx/name>*CURRENT_PRESET SET <string>
                                  GET = <string>
Configure Presets of Individual Routers
ROUTERS*<idx/name>*PRESETS CREATE <name> = <index>
ROUTERS*<idx/name>*PRESETS DELETE <name>|<index>
ROUTERS*<idx/name>*PRESETS*COUNT GET = <count>
ROUTERS*<idx/name>*PRESETS*<idx/name> GET = <xml>
ROUTERS*<idx/name>*PRESETS*<idx/name>*NAME SET <string>
                                           GET = <string>
ROUTERS*<idx/name>*PRESETS*<idx/name> CONNECT <input-index> <output-index>
ROUTERS*<idx/name>*PRESETS*<idx/name> DISCONNECT <input-index> <output-index>
ROUTERS*<idx/name>*PRESETS*<idx/name>*CAMERAS ADD <ip> <port> <cameranumber> = <index>
ROUTERS*<idx/name>*PRESETS*<idx/name>*CAMERAS REMOVE <index>
ROUTERS*<idx/name>*PRESETS*<idx/name>*CAMERAS*COUNT GET = <int>
ROUTERS*<idx/name>*PRESETS*<idx/name>*CAMERAS*<idx> GET = <xml>
ROUTERS*<idx/name>*PRESETS*<idx/name>*GPIIO ADD <devicename> <port> <pin> <pressed>
                                            GET  = <devicename> <port> <pin> <pressed>
ROUTERS*<idx/name>*PRESETS*<idx/name>*GPIIO REMOVE
ROUTERS*<idx/name>*MANUAL_CONTROL GET = <xml>
ROUTERS*<idx/name>*MANUAL_CONTROL*ENABLED SET <boolean>
                                          GET = <boolean>
ROUTERS*<idx/name>*MANUAL_CONTROL CONNECT <input> <output>
ROUTERS*<idx/name>*MANUAL_CONTROL DISCONNECT <input> <output>
Delays per Router
ROUTERS*<idx/name>*PRESET_DELAY SET <double>
                                GET = <double>
ROUTERS*<idx/name>*ENGINE_DELAY SET <double>
                                GET = <double>
GPIIO
GPIIO used on the TH machine (gpiio).
GPIIO*COUNT GET = <count>
GPIIO*MONITOR START
GPIIO*MONITOR STOP
GPIIO*MONITOR GET = <boolean>
GPIIO*<idx/name> GET = <devicename> <count inputports> <count outputports>
GPIIO*<idx/name>*INDEX GET = <index>
GPIIO*<idx/<name>*NAME GET = <string>
Notifications (only sent from TH) if gpi triggered when monitoring is on
GPIIO*MONITOR PRESSED  <devicename> <port> <pin>
GPIIO*MONITOR RELEASED <devicename> <port> <pin>
POST
Setup of the TH post system.
Set the Timecode Sources for Live and Post
POST*LIVE_SOURCE SET  <string>
                 GET = <string>
POST*POST_SOURCE SET <string>
                 GET = <string>
POST*TIMECODE_SOURCES GET <string>[,<string>]*
Session Commands
POST*SESSION CREATE <string>(create a new session)
             START (starts recording)
             STOP (stops recording)
             GET_LIST = <string>[,<string>]
             LOAD <string>
             DELETE <string>
             INFO_GET = <string>;[,<string>]*
Notifications
Loading saved session file progress as a percentage FILE_PROGRESS <float>. Loading of saved session file is complete FILE_FINISH.
Recording and Replay Commands
POST*PARAMETER_RECORDING GET <Parameter Name> = 1 (recording on) | 0 (recording off)
                         SET <Parameter Name> <0|1>
POST*PARAMETER_REPLAY GET <Parameter Name> = 1 (replay on) | 0 (replay off)
                      GET_DELAY <Parameter Name> = <float>
                      SET_DELAY <float>
TRACKING_SYSTEMS*<name>*RECORDING GET = 1 (recording on) | 0 (recording off)
                                  SET <0|1>
TRACKING_SYSTEMS*<name>*REPLAY GET = 1 (replay on) | 0 (replay off)
                               SET <0|1>
TRACKING_SYSTEMS*<index>*RECORDING GET = 1 (recording on) | 0 (recording off)
                                  SET <0|1>
TRACKING_SYSTEMS*<index>*REPLAY GET = 1 (replay on) | 0 (replay off)
                                SET <0|1>
TRACKING_SYSTEMS*<name>*REPLAY GET_DELAY = <float>
                               SET_DELAY <float>
TRACKING_SYSTEMS*<index>*REPLAY GET_DELAY = <float>
                                SET_DELAY <float>
SERVICES*RECORDING GET <service id> = 1 (recording on) | 0 (recording off)
                   SET <service id> <0|1>
SERVICES*REPLAY GET <service id> = 1 (replay on) | 0 (replay off)
SERVICES*REPLAY GET_DELAY <service id> = <float>
SERVICES*REPLAY SET_DELAY <service id> <delay>
LENSFILE
Lensfile, load, save and change on the Tracking Hub machine (LENSFILE*).
LENSFILE*LOGIN <pwd> = <xml_lenfsile> ??? correct error handling ???
LENSFILE*NEW
LENSFILE*LOCK <service_id> = <LockID>
LENSFILE*UNLOCK <LockID >
LENSFILE*XML_GET <LockID > = <xml_lenfsile>
LENSFILE*SELECT <lensfilename> =  lenfile (binary) loaded for edit
LENSFILE*SAVE <LockID,>
LENSFILE*SAVEAS <LockID, name>
LENSFILE*GROUP SELECT <LockID  parameter>
LENSFILE*GROUP NEW <LockID  parameter>
LENSFILE*GROUP ADD < LockID , parameter >
LENSFILE*GROUP DELETE < LockID , parameter>
LENSFILE*GROUP PARAMETERMOVE <LockID , parameter groupID >
LENSFILE*GROUP PARAMETERMOVE <LockID , parameter >   //move into a new group
LENSFILE*PARAMETER<parameter>VALUEADD< LockID , zoom,focus >
LENSFILE*PARAMETER<parameter>VALUEDEL< LockID , zoom,focus >
LENSFILE*PARAMETER<parameter>VALUECHANGE< LockID , zoom,focus,newvalue>
LENSFILE*ACTIVE GET = all active services
LENSFILE*PROXY SEND<LockID,string>
LENSFILE*PROXY REQ < LockID string> = <answer>
