Viz Artist 5.3.0
Release Date: 2024-10-17
These are the release notes for Viz Artist version 5.3.0. This document describes the user-visible changes that have been made to the software since release 5.2.1.
Note: Viz Engine maintains its release notes in a separate document starting from version 3.12.0.
Installer Notes
General
The Software ships with a bundle installer containing all necessary components. It is recommended to use the bundle installer when setup needs to be done manually.
  • Viz Artist is installed in C:\Program Files\Vizrt\VizEngine\VizArtist.
  • Visual C++ Redistributable files are not part of the .msi setup file anymore. These files are now installed with the bundle setup application (VIZENG-13210, VIZENG-12629, VIZENG-12701).
  • The new bundle setup application installs or upgrades Viz Artist together with its required Visual C++ Redistributable files (VIZENG-12936, VIZENG-13804).
  • All files contained in the bundle setup application can be extracted using the /dump command line option. This creates a sub-folder where the files are extracted (VIZENG-13020).
  • Multiple installations of Viz Artist are not supported.
  • The installer automatically upgrades (replaces) any existing Viz Artist 3.x installation. However, downgrading is currently not supported (VIZENG-7098).
  • The installer package is digitally signed (VIZENG-7378).
  • The user account must have SeCreateGlobalPrivilege (SE_CREATE_GLOBAL_NAME) enabled.
Windows
This software has been tested to run on the following systems:
  • Windows Server 2019
  • Windows Server 2022
  • Windows 10 (LTSC 1809)
  • Windows 10 (LTSC 21H2)
  • Windows 11
Information: Support for Windows 11 LTSC can not yet be announced officially as long-term stability tests are still ongoing.
Note: Only English language Operating Systems are supported.
  • It is recommended to install the latest Windows Security Updates and Patches, except Nvidia drivers.
  • .NET Framework 4.5 or higher is required (VIZENG-6036).
  • Minimum Windows Installer version is now 5.0.0.
  • To run Viz Artist/Viz Engine without Administrator privileges, you need to grant the following permissions:
    • SeIncreaseBasePriorityPrivilege
    • SeCreateGlobalPrivilege
    • SeCreatePagefilePrivilege
    • SeIncreaseWorkingSetPrivilege
Note: Viz Artist requires a minimum resolution of 1920x1080 pixels.
Windows
  • Network shares are not accessible from within Viz Artist when UAC is enabled or when running on Windows 10. The Viz Configuration page Local Settings has been extended for enabling Network drive linking (VIZENG-15594, VIZENG-15319).
UAC
  • Viz Artist is UAC aware. Log-files and additional files are stored in %VIZ_PROGRAMDATA%, which defaults to %ProgramData%\Vizrt\VizArtist. Configuration-files and profiles are stored in %ProgramData%\Vizrt\VizEngine. Temporary data is stored in %VIZ_TEMPDATA% which defaults to %TMP%\Vizrt\VizEngine. The default value can be changed in viz.cmd or on the command line of viz.exe.
  • Starting Viz Artist shows a UAC popup for VizStarter.exe (VIZENG-8683).
Changes
The following default shortcuts have been changed:
Scene Editor
Action
Old Shortcut
New Shortcut
Delete Object
BACKSPACE
DELETE
Camera View Zoom
X/Z
X/Z
Orthogonal Rubberband Zoom
X/Z
Q/W
Camera View Zoom In/Out in Orthogonal mode
SHIFT
removed
Mousemodifier in Scene Editor
Mouse Wheel to Position/Rotate/Scale (Undocumented and Classic only)
removed
Zoom In/Out
O + Mouse Wheel
Mouse Wheel
Switch to Back Camera (Orthononal)
Keypad 0
Keypad 1
X/Y/Z Key + Mouse Wheel
removed
Render Editor (On Air)
Off Air
ESC
Added CTRL+Q as additional shortcut
Toggle Preview
SHIFT + BACKSPACE
Added CTRL+P as additional shortcut
Stage
Select Keyframe Mode
S
Split into Rubberband Selection (R)
Spline Y Zoom Out
S
S
Set Stoppoint Mode
S
P
View Spline 1/2/3
CTRL Z/X/C
1/2/3
New Features
Key
Summary
VIZART-2683
Ability to manually refresh list of Graphic Hubs to enable autocompletion (e.g. if Graphic Hub is started after the login dialog opened)
VIZART-2267
Ability to switch Graphic Hub on the fly without restart Artist
VIZART-4734
Accept ZIP files to be dragged into Asset View or selectable in Import View
VIZART-4837
Add "Keep Aspect" to superchannels
VIZART-4846
Add "Update Mode" to Texture Renderers
VIZART-5001
Add blur function to Internal Image Editor
VIZART-4849
Add Channel blendmode, SuperChannel texture resolution
VIZART-4601
Add color indicators for Live Media Types
VIZART-4743
Add compilation status indicator for Shaders
VIZART-4960
Add new scene conversion capabilities dock
VIZART-5033
Add possibility to reset kerning settings for the whole text In Classic Text
VIZART-5032
Add tooltips to plugin icons in container dock
VIZART-4969
Add version information overlay for merged objects
VIZART-4593
Adding Shortcut Information (CTRL +F1)
VIZART-4928
Adjust autoscroll speed on drag&drop in scene tree depending on the mouse position
VIZART-4957
Advanced UI for VER particle system
VIZART-4681
Allow bookmarking fonts in Text font selection
VIZART-5217
Change asset view size via CTRL+mouse wheel
VIZART-4664
Config Option to apply color coding to entire container in scene tree
VIZART-4870
Create GUI for Softclip replacement using TextureRenderer for Viz Render workflow
VIZART-4725
Create new icon set for plugins
VIZART-1963
Creating VER lights should add automatically a container
VIZART-5088
Draw color marker on the complete row of the stage tree view
VIZART-4899
Expose Undo Redo History In User Interface
VIZART-638
Global and configurable shortcuts
VIZART-4955
Improve plugin thumbnails/font quality in UHD with Windows scaling
VIZART-4912
Improve Transformation Editor Layout
VIZART-4898
Improved Scenetree Container Search - Added support for Regular Expressions
VIZART-4315
Keep last recipient for GH Message Dialogue
VIZART-4150
Layer Editor should stick with the Scene Editor
VIZART-5198
Make old icons still available via config
VIZART-4877
Make workspace parameters resettable
VIZART-4804
New Blur's kernel type and parameters for SSAO
VIZART-4907
Plugins type selection should be remembered
VIZART-4553
Possibility to switch between Workspaces with keyboard shortcuts
VIZART-4582
Provide a library of shaders
VIZART-4755
Provide example code for TransitionShaders
VIZART-4866
Re-enable Back- and Frontlayer when MainLayer is VER
VIZART-4242
Recognize pbr image set and create PBR shader automatically.
VIZART-4979
Reflect value changes in Interface faster in Render output
VIZART-4897
Remove Layoutbutton from Scene - Rendering
VIZART-4809
Script Editor improvements on code indentation and autocompletion
VIZART-4933
Separate Gamma Correction and Lower/Upper Output Limits
VIZART-4430
Show available adaptive formats in GFX Channel
VIZART-4777
Show correct plugin tooltip for geometry plugins in Scenetree
VIZART-4801
Show only characters available for a specific font
VIZART-4420
Show served VizEngine instance number in VizArtist title bar
VIZART-4832
Support dragging images from Imagelibrary to Artist
VIZART-4965
WindowMask: add container selection for tracking
Fixed Issues
Key
Summary
VIZART-5060
Snapshot names are limited by 30 characaters
VIZART-5035
Scrolling stops midway in some plugin properties
VIZART-5028
Assets name will have (1) inside the name after copy&paste when using multiple different assets with the same name inside the same folder
VIZART-4985
Improve readability of the scripting documentation
VIZART-4981
Focus outline of Scene Editor not always correct
VIZART-4978
Fix wrong DPI scaling inside the stage editor
VIZART-4974
Artist crash when deleting items from the scene tree
VIZART-4927
Drag&Drop blocked by tooltip when Scene Tree is zoomed out
VIZART-4920
GraffiTex brush color alpha shouldn't be availble
VIZART-4914
Director offset, is measured in Seconds - even if Timeline is set to Frames or Fields
VIZART-4913
Deleting Materials on multiple container at once after Undo operation fails
VIZART-4906
Unlit Material has no Alpha-parameter
VIZART-4892
Bring back Front & Backlayer in Director Control window
VIZART-4862
Artist freezes when selected folder inside the import view will be updated in the background
VIZART-4854
List with SyncObjects for Superchannel Start Mode not visible
VIZART-4811
Import panel does not properly handle folder shortcuts
VIZART-4810
Modified Date/Descending sort order doesn't get updated automatically
VIZART-4761
Can't reset stop keyframe name
VIZART-4723
Artist freezes when expanding scene tree container
VIZART-4437
Material Editor icon not updating correctly
VIZART-4177
Favorites not cleared after remove asset in the new version of plugin overlay window
VIZART-3609
Scenetree: Horizontal scrollbar does not appear automatically
Known Issues
  • Due a technical limitation of QT framework, the focus of an input field can not be restored when switching containers.
  • Referenced Materials do not correctly update their icon if changed.
  • It is not recommended to run the User Interface within a Virtual Set environment, as it can cause timing issues under certain circumstances.
  • Viz One Browser: When the Viz One Browser window is minimized (either using the minimize button in the window bar, or WIN + D to hide all windows on the desktop), it can only be brought back to the screen by using the Restore and Maximize entries in the context menu of the window in the Windows taskbar.
  • Viz One Browser: The preview of clip elements in the Viz One Browser doesn't show the content correctly anymore when the browser window is moved to another display (e.g. second screen). The application must be restarted to bring back the clip preview.
  • Viz Engine render window is always on top when started in videowall mode -u1 -y -n and output system FULLSCREEN (VIZART-2400). Does not happen in mode -u1 -w or with any vga_preview and is independent on the number of monitors and if a mosaic is used or not.
    • What can be observed is that the output is always on top and it is not possible to get anything else on top (taskbar, other windows with ALT + TAB, task manager). SHIFT + BACKSPACE works only when Viz Artist has focus. When CTRL + BACKSPACE does not work it can be achieved with CTRL + ALT + DEL, task manager, ALT + TAB to Viz Artist and SHIFT + BACKSPACE. ALT + TAB does not work initially as the window is not shown. This behavior is actually desired to have the output of Viz Engine always on top (for example, interactive scenes shown on screens in the studio).
Windows
  • Right clicking on the Taskbar icon of Viz Engine starts a new instance. Starting an additional Viz GUI process is prevented on Windows 10.
  • On Windows version LTSC 1809: Logging out/in may be required for the fonts in the Viz Artist user interface to apply the set scaling after the user changes the Windows scaling setting.
Build Information
  • Platform Toolset: Visual Studio 2022 (v143)
  • Windows SDK Version: 10.0.22621
Documentation
Documentation for Viz Artist, Viz Engine and Viz Plugins are available at the Vizrt Documentation Center:
Installation and Support
Installation
The installation wizard guides you through the installation process. Make sure to close any running Viz Artist/Viz Engine application, prior to the installation. To run Viz Artist or Viz Engine independent of a database server, you need to install the Graphic Hub database software locally.
Support
