Gateway Administrator Guide
Version 5.3 | Published June 17, 2021 ©
MOS Protocol Support
MOS Profile Support
Gateway supports the following MOS profiles:
Profile
Definition
Supported
Vizrt Comment
0
Basic Communications
yes
1
Basic Object Based Workflow
yes
2
Basic Running Order/Content List Workflow
yes
3
Advanced Object Based Workflow
partly
Only mosItemReplace is used.
4
Advanced RO/Content List Workflow
yes
5
Item Control
partly
Only roCtrl is supported.
6
MOS Redirection
yes
7
MOS RO/Content List Modification
no
Gateway supports these MOS protocol versions:
Protocol version
Supported
2.6
yes
2.8.0
yes
2.8.1
yes*
2.8.2
yes*
2.8.3
yes*
2.8.4
yes*
2.8.5
yes*
*Both the Media Sequencer hosting the central Gateway and Media Sequencer clients must be upgraded to version 5.3 or later to support MOS Protocol version 2.8.1 or later.
