Viz Mosart Media Router Guide
Media Router Console Commands
It is possible to activate predefined salvos, to set individual crosspoints and to get router information by entering appropriate console commands. The following commands are available:
autofailover: Toggles auto failover mode. See the MosartMediaRouterService configuration.
autotake: Toggle autotake mode. See the MosartMediaRouterService configuration.
clear: Clears the console window
command: Syntax: command cmd [arg1] [arg2]. Executes a Media Router command with two optional arguments. The following commands are available:
backup: Enforces a backup of the Media Router database
get <filename> : Retrieves the current Media Router database and stores the database using the given filename.
reset: Resets the Media Router to the latest Media Router database stored on the file system.
restore <filename> : Restores the Media Router database to the content of the database stored in the given filename
flush: Flushes the current content of the Media Router to file storage. This command may be used to set the initial state of the Media Router
deletesalvo: Syntax: deletesalvo salvo. Deletes the specified salvo
exit: Exits the Media Router
getconfig: Syntax: getconfig client. Returns the current configuration for the given client. Used mainly for testing Mosart Server clients
getstatus: Returns an xml string containing current Media Router status.
help: Lists all commands
idle: Toggles active / idle mode of the Media Router service. Used for testing
list: Syntax: list [salvos|clients|sources|inputs|outputs|all]. List various router information
restore: Syntax: restore <filename>. Restores the Media Router database to the content of the database stored in the given filename.
save: Syntax: save <filename>. Retrieves the current Media Router database and stores the database using the given filename.
setactive: Activates the Media Router service
setcrosspoint: Syntax: setcrosspoint inport outport [salvo]. Sets a crosspoint in the given salvo:
If no salvo is given then the pending salvo is used. I.e. a set crosspoint request is sent to corresponding clients.
If the given salvo is not present, a new salvo will be created.
setsalvo: Syntax: setsalvo salvo. Fires the specified salvo
verbose: Turns on/off verbose diagnostics
Note when specifying crosspoints in console commands the inport/outport name shall be used to identify the corresponding port.
Media Router console command examples
List all current salvos: list salvos
List active connections: list salvos current
List pending connections: list salvos pending
List a specified salvo: list salvos M1.A
Connects video port M1.A.A to Quantel 2 / Port 1: setcrosspoint VS.Q2.1 M1.A.VA
Sets a crosspoint in a salvo: setcrosspoint VS.Q2.1 M1.A.VA M1.Backup
Fires a salvo: setsalvo M1.Backup
Deletes a salvo: deletesalvo M1.Backup
