Allows you to edit the animation path along which a map layer, image, text item, or drawing is animated.
To Change the Animation Path
Point to a point on the animation path. The cursor changes to a triangle.
Drag the point with the mouse pointer.
To Change the Curvature of the Animation Path
Hold down CTRL and drag from a point on the animation path to extend tangent handles from that point.
To Move the Tangent Handles Independently
Hold down CTRL and drag one tangent handle.
To Move the Tangent Handles Symmetrically
Drag one tangent handle.
