• Map layers: Allows you to move, resize, or rotate the label of a map detail.
  • Text layers: Allows you to edit the text in a text item, or resize the box.
Right-clicking the layer displays a context menu that allows you to add a country or region to the map, fit the map to a country or region, center the map on a country or region, add a new label to the map, or clear the selection.
