AI Terminal 2.0.0
Release Date: 2026-03-24
These are the release notes for AI Terminal version 2.0.0. This document describes the user-visible changes that have been made to the software since AI Terminal 1.1.0.
Features
Viz Engine I/O Modules
Added synchronization, input and output modules for receiving from and sending to Viz Engine. This has been possible also in older versions using shared memory modules, however, the new modules remove the need to write custom shared memory keys, and hence, make up a simpler user experience when sharing content with Viz Engine.
NVIDIA GPU Computing
The NVIDIA GPU computing toolkit was updated to CUDA 12, enhancing performance for newer graphics devices.
UX/UI Changes
Improved the user experience/interface with tooltips, the possibility to turn on and off an instance, and other minor changes.
Security
Third party dependencies were replaced and updated to remove potential security issues.
Documentation
Documentation for AI Terminal and related products are available on the Vizrt FTP and on the Vizrt Documentation Center:
Support
