Shared Memory Output
A shared memory output is used to integrate with applications that can receive video frame via shared memory (SMURF), for example Viz Engine.
This output requires a Shared Memory Sync created and assigned to the same tool.
Parameters
Name
Type
Explanation
Key
Text
Specifies the shared memory key.
Graphics Device
Selection
Specifies the graphics device used for texture sharing.
Sequential Timecode Name
Text
Specifies the name of the sequential timecode.
SMPTE Timecode Name
Text
Specifies the name of the SMPTE timecode.
Data
Type
Comments
Video
Supported formats:
  • RGBA (8-bit, SDR, or 16-bit HDR).
Audio
Experimental
Sequential Timecode
SMPTE Timecode
Errors and Warnings
Severity
Text
Potential Fixes
Error
Setup has failed. Check that a Shared Memory Sync is created and assigned to the same tool.
Create a Shared Memory Sync adapter and assign it to the same tool.
Error
Failed to write output.
Check that there is no other application that is writing to the same shared memory key.
Make sure the assigned image conforms with this output module’s requirements.
NDI Output
Use this output to integrate with other application capable of reading NDI.
Parameters
Name
Type
Explanation
NDI Output
Text
Specifies the name of the NDI output.
Data
Type
Comments
Video
Supported formats:
  • RGBA / RGBX (8-bit, SDR).
Sequential Timecode
Errors and Warnings
Severity
Text
Potential Fixes
Error
Initialization has failed. Revisit this outputs' configuration.
Check that there is no other NDI signal generated on this computer with the same name.
Error
Pose Data Sender
Use this sender to communicate detected pose data to the Pose Data Receiver Viz Engine Plugin (distributed with the Reality Connect tool).
Parameters
Name
Type
Explanation
Hostname
Text
Specifies the host address of the Viz Engine.
Number of joints
Number
Specifies the number of joints contained in the pose.
Port
Number
Specifies the communication port of the Viz Engine.
Data
Type
Comments
Tracked Positions
List of 3D points (with size N x 34) where N is the number of tracked persons.
Errors and Warnings
Severity
Text
Potential Fixes
Error
Check that the Viz Engine is running and has the same communication port configured as specified here.
Error
Check that the Viz Engine is configured with a valid UDP port (search the Viz Engine config for smm_udp_service).
Make sure the assigned point list contains a multiple of 34 points.
Socket Sender
Use this output to send data via TCP or UDP over network.
Parameters
Name
Type
Explanation
Hostname
Text
Specifies the host address to connect to.
Port
Number
Specifies the port number on which to connect.
Socket Type
Selection
Specifies the network protocol (TCP or UDP).
Data
Type
Comments
Binary Data
Errors and Warnings
Severity
Text
Potential Fixes
Error
Check that the specified network address is reachable on the specified network port and protocol.
Viz Engine Output
A Viz Engine output is used to integrate to a Viz Engine that can receive video frame via shared memory (SMURF).
This output requires a Viz Engine Sync created and assigned to the same tool.
Parameters
Name
Type
Explanation
Video Output Channel
Text
Specifies the SHM - SMURF channel to write to via shared memory.
Graphics Device
Selection
General Communication Port
Number
Specifies the port to communicate with the Viz Engine.
Text
SMPTE Timecode Name
Text
Data
Type
Comments
Video
Supported formats:
Audio
Experimental
Sequential Timecode
SMPTE Timecode
Errors and Warnings
Severity
Text
Potential Fixes
Error
Setup has failed. Check that the Viz Engine is running and accessible, and that a Viz Engine Sync is created and assigned to the same tool.
Create a Viz Engine Sync and assign it to the same tool.
Check that the Viz Engine is running and accessible via the configured port.
Error
