Datacenter 2.2.1
Release Date: 2024-10-24
These are the release notes for Datacenter version 2.2.1. This document describes the user-visible changes that have been made to the software since Datacenter 2.2.0.
New Features
Added a TCP Socket Connector Provider to connect existing TCP servers (RZT-12330).
Added the possibility to limit the refresh rate of the UI, to improve the usability of the application when using datasets that update too frequently (DCE-10).
Improvements
Changed application icon (RZT-12591).
Fixed Issues
Fixed issue when sending data to a Viz Engine Output using the "Auto" mode (RZT-13000).
Datacenter 2.2.0
Release Date: 2024-05-16
These are the release notes for Datacenter version 2.2.0. This document describes the user-visible changes that have been made to the software since Datacenter 2.1.2.
New Features
Users can now expose a time range slider with the scripts, allowing to filter data within a time range (RZT-11944).
It is now possible to join common endpoint parameters (RZT-12159).
Improvements
Changed JSON serialization to support large files (RZT-12098).
Fixed Issues
Fixed issues where data was sent to faulty generic TCP connection (RZT-12224).
Known Issues
Stats Perform authentication fails when the server used to fetch the time on the Datacenter machine, differs by more than +/- 60 seconds than the time of the Stats Performs servers (RZT-12115).
When having an active streaming dataset (for example, Tracab or Socket listener), the interaction with entries of other datasets (for example, adding a manual entry or copying an existing entry's value) may be hindered due to too frequent data updates (RZT-12200).
Licensing
Datacenter 2.2.0 requires a WIBU V3 software license.
Installing Datacenter
Install New Software (Required)
The setup file VizDatacenter-2.2.1.2470 .msi installs all required files to run Datacenter. The installation requires the following steps:
Step 1: Remove Existing Datacenter Versions (Optional)
Remove any existing installation of the Datacenter (recommended).
Step 2: Install Datacenter
Info: Running the Datacenter 2.2.1 installer requires Admin privileges.
Locate the file VizDatacenter-2.2.1.2470 .msi and double click it.
Follow the steps on screen and click the Install button when finished.
Step 3: Verify Datacenter's Installation
Make sure you have a valid Datacenter V3 WIBU license.
Navigate to http://127.0.0.1:5700 or double click on the Datacenter Desktop icon.
You should land on the following view (the Datasets list may be empty for a brand new installation):
Project Compatibility
Datasets created with versions older than 2.0.0, are not compatible with Datacenter 2.2.1.
Compatibility Notes
Datacenter 2.2.1 is compatible with:
Product | Version |
Windows | Windows 10 |
Viz Engine | 4.4.1 or newer |
Viz Libero | 8.2.0 or newer |
Viz Arena | 5.3.0 or newer |
Viz Arc | 1.7.0 or newer |
Documentation
Documentation for Datacenter is available at the Vizrt Documentation Center:
Support
