Datacenter 2.3.0
Release Date: 2025-02-24
These are the release notes for Datacenter version 2.3.0. This document describes the user-visible changes that have been made to the software since Datacenter 2.2.1.
New Features
Statsbomb and Google Sheets added as new data providers (DCE-14, DCE-35).
New authentication method HTTP basic, for Generic Webserver data provider (DCE-15).
Introduced a new timeframe slider as a script argument, that can specify additional seconds (DCE-26).
Improvements
Updated to .NET version 8 (DCE-17).
The datasets are now sorted alphabetically in the simple page (DCE-31).
Fixed Issues
Fixed issue with end point grouping (DCE-26).
Fixed wrong handling of maintenance period of the Core license (DCE-38).
Fixed issue where Datacenter was logging too many messages regarding license initialization (DCE-34).
Fixed issue where script input arguments where not updating correctly when a user made a selection (DCE-39).
Fixed license check issue, where the user could not get into a working state if the Core license was valid, but an add-on license expired (DCE-41).
Known Issues
Stats Perform authentication fails when the server used to fetch the time on the Datacenter machine, differs by more than +/- 60 seconds than the time of the Stats Performs servers (RZT-12115).
When having an active streaming dataset (for example, Tracab or Socket listener), the interaction with entries of other datasets (for example, adding a manual entry or copying an existing entry's value) may be hindered due to too frequent data updates (RZT-12200).
Licensing
Datacenter 2.3.0 requires a WIBU V3 software license.
Installing Datacenter
Install New Software (Required)
The setup file VizDatacenter-2.3.0.2564.msi installs all required files to run Datacenter. The installation requires the following steps:
Step 1: Remove Existing Datacenter Versions (Optional)
Remove any existing installation of the Datacenter (recommended).
Step 2: Install Datacenter
Info: Running the Datacenter 2.3.0 installer requires Admin privileges.
Locate the file VizDatacenter-2.3.0.2564 .msi and double click it.
Follow the steps on screen and click the Install button when finished.
Step 3: Verify Datacenter's Installation
Make sure you have a valid Datacenter V3 WIBU license.
Navigate to http://127.0.0.1:5700 or double click on the Datacenter Desktop icon.
You should land on the following view (the Datasets list may be empty for a brand new installation):
Project Compatibility
Datasets created with versions older than 2.0.0, are not compatible with Datacenter 2.3.0.
Compatibility Notes
Datacenter 2.3.0 is compatible with:
Product | Version |
Windows | Windows 10 |
Viz Engine | 4.4.1 or newer |
Viz Libero | 8.2.0 or newer |
Viz Arena | 5.3.0 or newer |
Viz Arc | 1.7.0 or newer |
Documentation
Documentation for Datacenter is available at the Vizrt Documentation Center:
Support
