These are the steps to configure a Manual dataset:
- Create a new dataset of type Manual, specifying a name and (optionally) a prefix to use to identify the dataset and its values, respectively:
- Click Add. You can now manually add new key-value data entries that work together with other datasets.
- In the Dataset Output panel, click on the + button:
- Fill the Key/Value pair in the panel that just opened. You can toggle the start activation state of the entry by using the toggle .
- Click the plus button to add the value to the entries. You should see the entry listed in the table below.
Please refer to the Filtering and Manipulating a Dataset Entries page to learn how to enable, disable and edit the entries added.
