Media Sequencer 5.8.1
Release Date: 2025-12-11
These are the release notes for the Media Sequencer (MSE) version 5.8.1. This document describes the user-visible changes since 5.8.0.
Fixed Issues
Fixed an issue where creating a template element from model with material_definition fielddef is not recognize and skipped (MSE-9929).
Fixed an issue where logging a message about an unexpected field in a list payload could cause a read access violation, if the list field name was a nullptr. The log now correctly reports the name of the corresponding field (MSE-9834).
Fixed an issue where the Media Sequencer did not validate STOMP URLs before using them. The MSE could attempt to use STOMP URLs with unsupported protocols when multiple STOMP monitor links were present in a document, causing failures and fallback to polling instead. The supported protocol is STOMP over TCP. This issue was observed with newer versions of Pilot Data Server (MSE-9862).
Fixed an issue in which superchannel_manager could resolve the incorrect background scene when playing a transition logic element with an alternative concept defined. This can cause superchannel_manager to wait for the wrong scene to transition, resulting in a timeout error and delay in the next taking element (MSE-9851).
Fixed an issue where MSE would fail to parse a URL with query parameters but an empty path (MSE-9869).
Fixed Gateway stops responding when a failover pair is activated (MSE-9897).
Fixed a possible unhandled exception when sending a POST or PATCH request to a Hierarchy Collection while also removing the collection node (MSE-9891, MSE-9896).
Fixed a possible crash when disabling the vcp_service actor while it waits for HTTP responses (MSE-9912).
Update WIBU CodeMeter Runtime to version 8.40a (MSE-9923).
Fixed invalid URI replied by Peptalk uri command for a Hierarchy Collection resource representing a show or playlist (MSE-9914).
Media Sequencer 5.8.0
Release Date: 2025-06-30
Note:
This release introduces two new licenses: MSE_PLAYOUT and MSE_FRAME_PREVIEW.
If you're upgrading a system used for playout, it will stop functioning after the update unless the MSE_PLAYOUT license is added in the MseLauncher's License settings. Please contact the Vizrt license team to obtain the required license.
Note:
Refer to comprehensive documentation of the Media Sequencer (MSE) in the MSE Manual. When the sequencer is running, this manual is available at http://localhost:8580/mse_manual.html. You can also access the manual by opening the local file www/mse_manual/index.html in the MSE install directory.
System Requirements
As of version 3.1, Media Sequencer is only available as a 64-bit software.
Software
Supported operating systems:
Server: Windows Server 2016 or higher.
Workstation:
Recommended: Windows 11.
Windows 10 (LTSC 21H2) is also supported.
Media Sequencer 5.8.0 is 64-bit software, it can only be run on 64-bit versions of Windows.
Operating systems that have reached their end of life cycle and are no longer officially supported by their manufacturers, are not supported for use with the MSE.
A Media Sequencer used with a Viz Pilot system needs to access the database which Viz Pilot uses. For Viz Pilot version 6 or older, this is an Oracle database, which previous Media Sequencers had to connect to directly.
While this configuration remains supported, Media Sequencer 4.0 and Viz Pilot 7 introduced the ability for the Media Sequencer to connect to the Pilot Data Server instead. The Pilot Data Server introduced in Viz Pilot 7 can in turn, run with either an Oracle backend or a Viz Graphic Hub backend.
When a Media Sequencer is set to connect directly to the Oracle database, an Oracle Database Client (Runtime or Administrator) is needed. Administrators must take care to install the 64-bit version of the Oracle Database Client.
Microsoft .Net
The Media Sequencer requires Microsoft .Net framework 4.7.2 (full) or newer to be installed on the machine. The installer notifies the user if .Net 4.7.2 is not found.
Licensing
As of version 5.4.0, Media Sequencer requires WIBU licensing. The WIBU CodeMeter runtime must be installed and configured, to make Media Sequencer licenses available. CodeMeter is installed as part of the new bundle installer.
Selecting which license container to use and which licenses to enable, is configured from the Media Sequencer launcher with elevated privileges. The launcher generates a license configuration file licenses.json in the Media Sequencer data directory. A Media Sequencer core license is required to launch. Additional licenses must be enabled for running the sequencer as a central Gateway, or for licensing the Viz Multiplay client.
As of version 5.5.0, Media Sequencer supports Viz License version 3 (movable licenses), in addition to the already supported Viz License version 2 introduced with 5.4.0. The launcher has been changed to allow selecting between version 2 and version 3 licenses, in the case where both are available.
The MSE can be configured to alert about license expiration in two ways, either via email (SMTP) or via Graphic Hub journal messages. This alert ability can be configured from the License Alert configuration, available from the launcher when the MSE is running.
For information about how to configure MSE licenses and license alerts, refer to the MSE WIBU licensing documentation (available from the Windows Start menu).
Hardware
System requirements for hosting the Media Sequencer:
Workload | Processor | Memory |
Standard | 2 cores / 4 threads | 6 GB |
Demanding | 4 cores / 8 threads | 12 GB |
Running other resource-intensive software on the same machine is not recommended as it can slow down the Media Sequencer.
Virtualization
The Media Sequencer may be run inside a virtual machine. We recommend following the table above when allocating resources to the virtual machine. For time-critical operations we recommend using the Element Scheduling REST API to trigger frame accurate playout.
Applications and Components Recommended with this Release
Viz Trio 4.4.3 or higher
Viz Multiplay 3.3.0 or higher
Viz Pilot 8.9.3 or higher
Viz Pilot Edge 3.3.0 or higher
Template Builder 3.3.0 or higher
Pilot Data Server 9.3.1 or higher
Preview Server 4.7.1 or higher (Preview Server 5.0.0 requires MSE Frame Rendering API)
Graphic Hub 3.9.2 or higher
Graphic Hub REST 2.9.2 or higher
Graphic Hub ImEx Agent 2.1.2 or higher
Viz Engine and Viz Artist 5.4.1 or higher
Viz One 7.6.2 or higher
The Media Sequencer has been designed to have backward compatibility with older versions of these components. We work hard to keep the Media Sequencer backward compatible, however, for some older versions of the Delphi-based clients (for example, Director and Viz Trio), we highly recommend upgrading these clients to a more recent version.
Silent Installation
Silent installation allows the Media Sequencer to be installed without user interaction.
To perform silent installation, open a command shell as an administrator and run the Media Sequencer bundle installer with the -s or --silent option.
It is also possible to select features to be installed from the command line.
To get all options available, run the Media Sequencer bundle installer with the --help option.
Example command:
MediaSequencer.BundleInstaller-5.x.x.xxxxx.exe -sExample command to install Media Sequencer with Gateway controller:
MediaSequencer.BundleInstaller-5.x.x.xxxxx.exe -s --mse-gw-controllerA license configuration file licenses.json in the Media Sequencer data directory (C:\ProgramData\Vizrt\Media Sequencer) is required to run Media Sequencer. If licenses.json is missing, the installer will prompt the user to create it using the Media Sequencer launcher. Note that license configuration cannot be changed using the non-admin Media Sequencer launcher.
To avoid the automatic license configuration prompt before running silent installation, copy licenses.json from another successful Media Sequencer installation to the Media Sequencer data directory. See the License section for more information.
Running the Media Sequencer
It is highly recommended that the Media Sequencer is run as a system service, rather than in a console. This is the default behavior after installing.
To start the Media Sequencer, licenses must be configured. This can be done from the launcher with elevated privileges. For more information about licensing see the License section, and the MSE WIBU licensing documentation (available from the Windows start menu).
The Media Sequencer can be started and stopped using the Media Sequencer launcher. You can do both with and without elevated privileges. In order to start and stop the Media Sequencer without elevated privileges, open the shortcut Media Sequencer (non admin) available from the Windows Start menu. Note that it is not possible to configure any settings from the launcher without elevated privileges.
Removed Functionality
Deprecated Plugins
Plugins are sometimes deprecated with a new release of the MSE. These plugins will no longer be available in the next release. You need to migrate away from using them.
The following plugins are deprecated in this release:
websocket: The websocket plugin mostly used for providing peptalk, treetalk and STOMP protocols over a websocket connection, is deprecated with this release of the Media Sequencer. Clients using these websocket APIs should migrate to using the APIs served by the HTTP server with discovery via the service document.
Media Sequencer Core Enhancements and Fixes
Frame Rendering API
A new Frame Rendering API is now available in Media Sequencer 5.8. This REST API allows clients to request snapshot previews of graphics scenes rendered by Viz Engine directly from the Media Sequencer. The API supports both GET and POST requests, returning PNG images of the rendered frames. Snapshot requests can be customized with VDF payloads, scene paths, and image properties such as size and aspect ratio. Frame Rendering API requires MSE_FRAME_PREVIEW license.
Frame Rendering resources are managed as a collection, represented by the Frame Renderer Collection resource. The collection contains Frame Renderer Collection Entry resources, which correspond to Viz Engine endpoints used for frame rendering. To use the API, clients create a new Frame Renderer Collection Entry resource via a POST request to the Frame Renderer Collection, then follow the atom links provided by the Frame Renderer Collection Entry resource for further operations. For example, the atom link with rel='snapshot' is used to request snapshot previews.
The Frame Rendering API also provides STOMP monitoring for real-time updates on the status of Frame Renderer Collection Entries. Clients can subscribe to the atom link with rel='monitor' in the Frame Renderer Collection document to receive these updates (MSE-9290, MSE-9516).
For more details, see the REST API documentation.
Initial support for Pilot Core Service
Pilot Core Service (PCS) will be the next generation Pilot backend, based on a new scalable and secure document database (Viz Asset Management). This release of the Media Sequencer includes initial support for PCS, with support for resolving Pilot elements from PCS with Playable Cache (MSE-9262).
Update WIBU CodeMeter Runtime to version 8.20a (MSE-9559).
Support Single Sign-on authorization in Playable Cache
Support has been added to set up Single Sign-on (SSO) authentication with client credentials for the MSE. This enables Playable Cache to obtain SSO access tokens for authorizing requests for protected resources from trusted services.
SSO configuration is done from the MSE launcher in the settings window. An OpenID issuer URL, client ID, client secret, scope, as well as a list of trusted services that require SSO authorization must be configured. The MSE will not attempt to authorize requests to untrusted services (MSE-9416).
New Configuration Option: Ignore take_duration on Graphic Elements
A new global setting has been introduced: /config/take_duration/ignore
When set to 'yes', this option disables the automatic 'take out' of graphic elements based on the take_duration attribute. This is particularly useful in Channel Branding workflows where the automation system controls when elements are taken out, but the take_duration value is still displayed in the user interface for reference (MSE-9677).
Playable Cache Backend Added as Option in Pilot Database Config GUI
Playable Cache backend has been added as an option in the PilotDbConfig web app, as an alternative to legacy Oracle database or Pilot Database with vcp_service (MSE-9557).
New Plugins
Plugin Enhancements and Fixes
viz
Handler setting without both host and port is now invalid instead of use default host and port (MSE-9508).
http_server
Expose viz layer in Output Entry for viz_video handlers. Clients can select viz layer by specifying a 'viz_layer' field in VDF payload of the Output Entry. Default value is 'BACK' (MSE-9544).
Provide a 'name' field in VDF payload of the Output Entry and Output Settings resources. Clients may specify the created handler name when POSTing to Output Collection resources by setting the 'name' field (MSE-9554).
Fixed an issue where GET requests to Videowall Collection resources containing invalid videowall entries return 404 Not Found (MSE-9596).
Added a read-only 'mode' field to the VDF payload of Output Entry and Output Settings resources for superchannel viz and superchannel video handlers. This field shows if the handler operates in 'superchannel_arm_and_fire' mode. Clients cannot create, delete, or modify 'superchannel_arm_and_fire' handlers via Output Collection, Output Entry, or Output Settings, as these handlers belong to video walls (MSE-9709).
Added support for providing template descriptions for scene alternatives upon POST/PUT of BGFX mastertemplate documents (MSE-9501).
Added support for POSTing a scene to a video wall scene collection without requiring Graphic Hub credentials. This is done by POSTing a VDF payload that contains all needed information about the scene, as an alternative to the MSE resolving this information from Graphic Hub REST (MSE-9670).
Added support for BGFX expertmode markup upon POST/PUT of BGFX mastertemplate documents (MSE-9672).
Two new Profile Commands have been added, "direct_take" and "direct_update". They allow directly taking or updating an element on a specific channel and renderer layer. These commands schedule temporary elements and are suited for simpler integrations that do not require the normal playlist-based workflow (MSE-9654).
Added support for creating Trio Shows through the MSE REST API (MSE-9647).
Made the 'alternative-concept' field for outputs in the Profile REST resource available, even when the concept has not been overridden for the output (MSE-9612).
Empty video handlers are now excluded from the output collection feed (MSE-9553).
Added support for inserting MOS objects from Pilot Edge into a playlist with a PATCH request to the hierarchy collection feed (MSE-9599).
Added support for inserting multiple entries (atom entries or MOS objects) into a playlist with a single PATCH request to the hierarchy collection feed (MSE-9623).
playable_cache
Allow to change 'poll_interval' configuration on-the-fly. When changing, the current polling task will be rescheduled with the new interval (MSE-9569).
Fix a crash when building a template with generators in VDF model (MSE-9648).
Added support for monitoring template atom entries with inline BGFX mastertemplate as part of the document (MSE-9438).
Added support for resolving pilot templates with execution logic provided as an auto-convertible document (MSE-9579).
Added support for live-update functionality for pilot templates resolved by Playable Cache. This includes support for live-update provided as an auto-convertible document (MSE-9540).
Added support for context variables to category channel mapping in Playable Cache, provided as an auto-convertible document. Channel names are resolved with a new Playable Cache namespace handler (MSE-9534).
Added support for resolving pilot templates containing concept to label mapping provided as an auto-convertible document. The mapping can be used by control clients to show user readable labels for concepts instead of the concept IDs (MSE-9541).
Added support for authorizing requests for protected resources using access tokens obtained with client credentials (MSE-9416).
Added pilot metadata node to data elements resolved with Playable Cache. The metadata node will contain an editor link if provided in the atom entry for the pilot element. This editor link can be used by clients to open the element for editing in Pilot Edge (MSE-9600).
gateway
Added support for keepAlive messages between MSE Client and Gateway in order to keep the connections alive when idle (MSE-9606).
element
Added support for resolving category channel from channelselector in mastertemplate during playout of elements (MSE-9556).
relative
Added support for resolving category channel from channelselector in mastertemplate during playout of filled presets (MSE-9602).
Known Issues
This section describes issues that have been reported but not resolved.
Media Sequencer does not support live-updates from Pilot Core Service (PCS)
Currently, Playable Cache attempts to resolve the auto-convertible live-update link in Pilot templates. In future versions of the Media Sequencer, Playable Cache will in addition support inline live-update document needed to support live-update from PCS. This will allow all template information to be retrieved in a single request (MSE-9749).
Cannot Configure WIBU SmartBind Loose Licenses in MSE Launcher
When activating a Software Container on a virtual machine or in a cloud environment via the license portal, additional manual configuration is required (MSE-9666).
Workaround Steps
Assign the required licenses in MSE Launcher.
Close the MSE Launcher application.
Navigate to the following file location: C\:ProgramDataVizrtMedia Sequencerlicenses.json.
Open the
licenses.jsonfile in a text editor with administrative privileges.Locate the relevant license container and change its
"location"value from"0"to"1".
Note:
Editing the file requires the text editor to be run as an Administrator.
Incorrectly displayed WIBU License in Media Sequencer Launcher
If multiple versions of a license are available on a license server, the license displayed in the main window of the Media Sequencer Launcher may show an incorrect Count and Expiration date compared to what is selected in the Media Sequencer Settings (MSE-9522).
Issue with "Out" Command when Performing Frame Accurate Playout of Transition Logic with Video
If you do frame accurate out and then two take operations of transition logic elements with video, the second video will not start from the beginning of the clip (MSE-7046).
MSE may Report the Main Thread Slow on the Re-initialization Process
MSE may report the main thread to be slow while it is reinitializing. This issue typically occurs when the Viz Pilot database is at a remote location.
Inaccurate Video Availability Progress if the Video Clip is Deleted from a Publishing Point
Availability progress of a video clip is not immediately reset to zero when the related video clip is deleted from a publishing point. This is due to the limitation of the Viz One API feedback (ME-664).
Ordering of Fields in Payloads and Models Not Respected
Media Sequencer does not respect ordering of fields and fielddefs in VDF payloads and models, meaning that for example, a payload inserted using the REST interface may have the fields in a different order when later obtained from the REST interface. This has no consequence for playout, but may cause unexpected reordering of fields and fielddefs in software used to display or edit payloads or models (MSE-6565).
Superchannels May Become Stuck in Transitioning State when Arm/Fire Non-Existing Video Clips
When operating in superchannel arm/fire mode, the Media Sequencer requires feedback from the Viz Engine to ensure that the Viz Engine has finished transitioning between playing and pending subchannels before sending next commands; otherwise, the next commands may affect the incorrect subchannel. The Media Sequencer holds any new commands during transitioning until it receives transition completed feedback from the Viz Engine. When a user arms a non-existent video clip, the Viz Engine does not notify the Media Sequencer that the clip is not available. If the user continues to fire this non-existent video clip, the Media Sequencer will stop executing new commands until the viz_feedback_timeout_seconds is reached. This viz_feedback_timeout_seconds can be configured in superchannel_manager handler settings (MSE-8414).
Documentation
Documentation for the Media Sequencer is available in the bundle installer on the Vizrt FTP.
Once installed, documentation is available within the MSE, as described above.
Support
