Plug-ins 5.6.0
Release Date: 2026-11-19
These are the release notes for Plug-ins version 5.6.0. This document describes the user-visible changes that have been made to the software since release 5.5.0.
Information: Viz Maps plug-ins are no longer included in the Bundle installer of Viz Engine and need to be installed seperatly.
This document includes the Release Information for:
  • Plug-ins
  • DataPool Plug-ins
  • Viz Engine Basic Plug-ins
  • Viz Engine Extensions Plug-ins
  • Viz World/Viz Maps Plug-ins
  • PixelFX Plug-ins
  • Socialize Plug-ins
Installer Notes
The installation wizard guides you through the installation process. Make sure to close any running Viz application prior to the installation. To run Viz Artist or Viz Engine independent of a database server, you need to install the Graphic Hub database software locally.
General
The Software ships with a bundle installer containing all necessary components. It is recommended to use the bundle installer when setup needs to be done manually.
  • The basic plug-ins are installed by default. All other plug-in packages are optional.
  • Softclip comes in 32-bit (default) and 64-bit versions. To use the 64-bit version, replace the file Softclip.vip in \plugins with the one from the subfolder %ProgramFiles%\VizEngine\plugin\disabled.
Upgrade Notes
  • All plug-in installers are installed per-machine starting with 5.2.0. Uninstalling all previous per-user plug-in installations before upgrading is recommended to avoid duplicated installer entries.
  • The path for the DataPool-related files has been set to %\ProgramData%\vizrt\VizEngine\DataPool.
New Features
New Features: Plug-ins
KeySummaryComponents
VIZPL-2341Maps: GeoCameraLink pluginBasic
VIZPL-2339Particle System: add gizmos to emitter typeBasic
VIZPL-2292GeoNavigator, ControlGeoNavigator Basic, Control
VIZPL-2291ControlGeoJson - control plugin to be able to set geojson on containerBasic
VIZPL-2288Inconsistent offset behavior for pie slices when using Pie Slice plugin with Pie Values and Control PieBasic
VIZPL-2250Improve Classic Substance UIBasic
VIZPL-2231Presets plugin: long preset transition doesn’t cancel when interrupted by shorter preset transitionControl
VIZPL-2223More options for the Texture Slot plugin inside the Control Image plugin in Trio workflowControl
VIZPL-2102ImageProportions plugin for VER pipelineBasic
VIZPL-1759Audio Plugin to be muted if underneath a hidden containerBasic
New Features: Basic Plug-ins
Fixed Issues
VIZPL-2376SplineStrip crashes after adding nodeBasic
VIZPL-2366Advanced counter plugin fails aboth 6 digits when using odd numbersBasic
VIZPL-2362Trio scroll plugin gets stuck in endless loopBasic
VIZPL-2355Spline Path plugin doesn't draw pathBasic
VIZPL-2302Browser plugin cache control does not work in VERBasic
VIZPL-2230Browser plugin doesn't output audio via the MatroxBasic
VIZPL-2190Connector Plugin not working in VERBasic
VIZPL-1901Browser plugin zoom value kept after scene close and reloadBasic
Security Updates
Known Issues
General
VIZPL-2399Grid plugin doesn't restore saved values when opening a sceneCommon
VIZPL-1975TrioScroll plugin does not create proper VDFControl
VIZPL-1765VLC plugin "loop" function not supported and needs to be removedSocial
Plug-ins Known Issues
  • On Dual channel setups Browser Plug-in causes performance impacts on second or higher instance.
  • RTT Shaders consume about 300-400 MB of RAM once they are initialized. If you do not use them or if you don't own a license, it is recommended to disable the plug-ins in the configuration panel in section Plugins (VIZENG-10224).
  • Softclip: Lagarith Codecs are playing slower on Windows Server Operating Systems. This issue can be solved by enabling Use Multithreading option in Lagarith codec configuration.
Socialize Plug-ins Known Issues
  • Viz Engine can't access mapped network shares on Windows 10 for security reasons. If media files are stored on a network share, please be sure to enable Network Linking in Viz Configuration (Local Settings).
  • Trio 3.x do not have full Unicode support (e.g. not all Emojis can be set by these control applications).
  • VLC plug-in requires some additional steps:
Viz World/Viz Maps Plug-ins Known Issues
  • When freezing a Map, including Pyramids in CWMClient, Hop scenes no longer work (VIZPL-45).
Supported Hardware and Software
This software has been tested to run on:
  • Windows 10 LTSC 21H2
  • Windows 11
  • Windows Server 2019
  • Windows Server 2022
Note: Only English language Operating System(s) are supported.
Build Information
  • Platform Toolset: Visual Studio 2022 (v143)
  • Windows SDK Version: 10.0.22621
Documentation
Info: Starting with Viz Artist/Viz Engine 5.4.0, the installer no longer installs an offline documentation.
Documentation for Viz Engine, Viz Artist and Viz Plugins is available online on the Vizrt Documentation Center:
Support
