The Apply Shared Memory plug-in allows values to be transferred into Viz Engine using mechanisms provided by shared memory maps that can be applied to control plug-ins such as Control Text. Just as Control Object acts as a distribution hub for content provided by control applications, Apply Shared Memory acts as a distribution hub for content provided by external systems feeding real-time data through the shared memory maps.
The Control plug-ins that Apply Shared Memory can apply content to resides in the same folder.
Just like Control Object, Apply Shared Memory only applies values to Control plug-ins residing in the subtree of the scene tree where Apply Shared Memory resides. Also like Control Object, it matches the keys of incoming content with the field identifiers of individual control plug-ins to determine where to apply which incoming content value.
Apply Shared Memory Properties
  • Shared Memory Source: Specifies which shared memory map to apply values from. The Scene, Global and Distributed choices select the shared memory maps that are referred to as Scene.Map, System.Map and VizCommunication.Map respectively in the section.
  • Memory Base Key: Provides the key prefix path to combine with the field identifiers of control plug-ins to determine the key to look up in the chosen shared memory map when applying values to a particular field exposed by a control plug-in.
  • Expose Base Key: Exposes the Memory Base Key property as a controllable field. Once this option is turned on the properties Field Identifier and Description as described in the Common Control Properties section can be specified.
    The Expose Base Key property is typically used to allow a control application to control the base key which determines where in the shared memory map to pull values from. However, since the exposed property is an exposed control field like any other, a parent Apply Shared Memory plug-in can be used to make the shared Memory Base Key property controllable by external systems through a shared memory map.
  • Shared Memory Keys: Lists the currently applied shared memory key and value pairs.
Choosing whether to allow the exposed field to be controlled by control applications or external systems feeding the shared memory map is done by placing either a Control Object or another Apply Shared Memory plug-in on a parent container, respectively.
Visualize Composite Data Structures
The Memory Base Key property combined with the field identifiers exposed by Control plug-ins can be seen as a way to visualize sets of related key-value pairs stored in shared memory maps. While the Memory Base Key property specifies where in the shared memory map to locate the set of related key-value pairs, the exposed field identifiers specify which of the related key-value pairs from the selected set to visualize in a particular way in the scene subtree.
For example, the Memory Base Key property can specify a shared memory path representing a particular stock symbol, while the field identifiers of Control plug-ins pick out particular values such as stock name, value and change from that location in the shared memory map.
Since Apply Shared Memory only affects the scene subtree it is placed on, visualizing multiple composite data structure instances sharing the same structure and presentation can easily be achieved by copying subtrees and only change the Memory Base Key property.
For example, design a stock presentation design once, and copy it many times to create a scene showing several distinct stocks using the same visual style. Turning on the Expose Base Key property gives users of control applications control of which stocks to show in each presentation copy, while the data content for each stock is still supplied in real-time through the shared memory map.
How Shared Memory Keys are Determined
The shared memory keys used to look up values in a shared memory map is constructed by the combination of an absolute path specified in Memory Base Key property and an either relative or absolute path consisting of the field identifier of an exposed field. Any path starting with a slash (/) is considered an absolute path, while all other paths are considered relative.
If the field identifier is an absolute path, then that absolute path alone is the result of the resulting shared memory key used. For example, the field identifier /weather/norway/bergen/temperature results in the shared memory key /weather/norway/bergen/temperature regardless of what the Memory Base Key property is.
If the field identifier is a relative path, the path is interpreted relative to the absolute base path provided in the Memory Base Key property, and the absolute path resulting from that interpretation is used as the shared memory key. For example, a Memory Base Key property of /weather/sweden/stockholm and a field identifier of temperature results in the shared memory key /weather/sweden/stockholm/temperature.
Like file system paths, a path segment consisting of a single dot (.) is considered referring to the current directory, while two dots (..) is considered referring to the parent directory. This notation is resolved to a regular absolute path before using the result as a shared memory key. For example, a Memory Base Key property of /weather/./norway/trondheim and a field identifier of ../bergen/windspeed resolves to the shared memory key /weather/norway/bergen/windspeed.
To Visualize Stock Data from Shared Memory
This procedure visualizes composite content fed through a shared memory map to the Control plug-ins Control Text, Control Num and Control Sign Container.
  1. Create a new container.
  2. Drag and drop Apply Shared Memory onto this container.
  3. Set the Memory Base Key property of the Apply Shared Memory plug-in to /stocks/nyse/ibm.
  4. Create two text geometries as children of this container.
  5. Drag and drop Control Text into the first text geometry container.
  6. Set the Field Identifier property of Control Text to name.
  7. Turn off Use formatted text property of Control Text.
  8. Drag and drop Control Num onto the second text geometry container.
  9. Set the Field Identifier property of the of Control Num to value.
  10. Create a third container as a child of the Apply Shared Memory container.
  11. Drag and drop Control Sign Container onto this container.
  12. Set the Field Identifier property of Control Sign Container to value.
  13. Create three text geometries as children of the Control Sign Container container.
  14. Drag and drop Control Num onto each of these three text geometry containers.
  15. For each of these three Control Num plug-ins, set the Field Identifier property to change.
  16. Arrange the layout of the text geometries, and apply materials for styling.
To Test Stock Visualization
To test that stock visualization commands can be sent to populate the global shared memory map, see the descriptions in the section.
While these commands are suitable for testing the designs, a real external system that feeds the Viz Engine with data would use a more efficient data transfer protocols to populate the shared memory map. See the External Data Input section of the Viz Artist User Guide for information about sending data efficiently using UDP.
When changing a value in the shared memory map that is visualized by a Control plug-in the scene updates immediately to reflect the new value. The shared memory map can be populated with stock values for many stock symbols, including stocks that are not visualized at the moment. As soon as the Memory Base Key property of Apply Shared Memory is changed to visualize the values for a different stock symbol, and the scene updates immediately to reflect the value previously populated into the shared memory map for that stock symbol.
