The Transition Logic engine for Viz. Creates two A/B placeholder containers with cross-fade directors, enabling animated switching between loaded graphics with object caching.
Note: This plug-in is located in: Plugins -> Container plug-ins -> Container
Overview
Toggle is the runtime engine behind Transition Logic. When added to a container, it:
  1. Creates two placeholder subtrees (A-side and B-side) as children.
  2. Generates cross-fade directors (AX/BX) with a default 1-second alpha dissolve.
  3. Generates object directors (AO/BO) where loaded scene animations are placed.
  4. Loads graphics onto the invisible placeholder, then switches with an animated transition — the viewer never sees a loading state.
  5. Caches loaded objects for instant re-use.
Key concept — $current and $other The visible placeholder is always named $current; the invisible one is $other. On switch, the names swap. Content is loaded onto $other, data is pushed via ControlObject, then switch triggers the cross-fade.
Prerequisites
  1. Give the container a unique, descriptive name (for example, BannerLyr) — this becomes the Toggle layer name and director name.
  2. The container must have no existing children — Toggle creates its own.
  3. Create a Director with the same name as the container.
  4. The Director must have at least two stop points: $O (Out, at frame 0) and at least one visible state (for example, $IN).
  5. Add Toggle to the container.
  6. Click Default Keyframes to generate the GOTO_TRIO action channels.
Description and Methodological Considerations
Toggle plug-in is one of the main building blocks of Transition Logic, and it is in general a relatively simple plug-in. When the Toggle plug-in is added to a container, it creates two child containers that act as placeholder containers for objects that can toggle on and off screen. In addition, it also creates some utility directors in the stage.
Toggle Placeholder Containers
The two placeholder containers correspond to an A-side and a B-side. Each of the placeholders again have a child container; one named current the other named other. The current is typically the visible container, while the other is not visible. At the time of a switch, these containers switch names. This means that at any given time it is not possible to know if the current parent is the A side or the B side. It is the responsibility of the Toggle plug-in to keep track of this.
Toggle Directors and Key Frames
The Toggle plug-in creates two directors each containing a default one second cross fade animation. These animations are placed in the AX and BX directors. AX can be interpreted as the A-side cross fade. The animations can be modified to show any kind of transition, but it is important that the AX and BX are the same.
In addition to the cross fade directors the Toggle plug-in also creates placeholder directors for the object animations. Merged objects that are loaded into these placeholder containers during playback may contain animations embedded in the geometry object. The object animations are automatically added as a sub-director to the AO or BO director depending on if the object is being loaded on the A-side or B-side.
Caution: It is NOT recommended to manually adjust the AO and BO directors.
There are two different scenarios of when the utility directors are triggered:
  1. When there is a state change. When there is a state change, the Toggle-Layer director is animated from the current state to the required next state. In this scenario, the utility directors are triggered according to the toggle Key Frames in the stage. This means that it is the position of these Key Frames that determine the timing of when the utility directors are triggered.
  2. No state change, only changing the current object. When there is no state change, there is no movement of the Toggle-Layer director. In this case, the Toggle switch action is triggered, which animates the utility directors at the same time; animating the current object out and the next object in at the same time.
Note: Placeholder containers and directors are only generated if none exists from before.
Toggle has a built-in support for object loading. Enter the path to an object (for example, GEOM*myfolder/myobject) into the Object field, and the plug-in loads this object on the other container. The object is by default invisible and can be loaded with data, before activating the Switch action to show the object.
An object loaded this way is cached, so that requesting the same object again does not trigger loading again. The object cache can also be preloaded by specifying all the geometries that should be preloaded before initializing the Toggle plug-in. Preloading of the objects needed by the Toggle plug-in is done when a playlist is initialized. For this reason the Preload Object text field should normally not be manually modified in Viz Artist.
Director Naming Convention
For a Toggle container named BannerLyr, the following sub-directors are created:
Director
Purpose
Editable?
BannerLyr
Controlling director — contains GOTO_TRIO action channels (switch_in, out, switch). This is what Transition Logic addresses.
Stop points only
BannerLyr,AX
A-side cross-fade — default: alpha 0→100 over 1 second. Customise for slides, wipes, 3D flips.
Yes — but must match BX
BannerLyr,BX
B-side cross-fade — must always be identical to AX.
Yes — must mirror AX
BannerLyr,AO
A-side object animation — auto-managed. Loaded scene animations become sub-directors here.
No — auto-managed
BannerLyr,BO
B-side object animation — auto-managed.
No — auto-managed
AX and BX must always be identical: Toggle may load content on either side. If the cross-fade animations differ, transitions will look inconsistent depending on which placeholder is active.
Before adding the plug-in to a container in a scene, please make sure that:
  1. You give the container a unique and sensible name. This name becomes the Toggle-Layer name. Also, as the Toggle plug-in automatically generates directors, which are named based on the container name and its parents names, it is worth considering if the location of the container that hosts the Toggle plug-in is in the correct position in the scene tree.
  2. The container the Toggle plug-in is added to must not have any child containers.
  3. A director with the same name as the container (Toggle-Layer name) is created.
  4. The director has a minimum of two stop points and that these stop points are named correctly. The names must correspond with the Toggle-Layer states.
IMPORTANT! One of the Transition Logic requirements is to have a stop point named “O”. Best practice is to always name the first stop point “O” (frame 0).
After the Toggle plug-in has been added to the container, the plug-in icon can be clicked to see its properties. Clicking the Default Key Frames button creates the most commonly used Key Frames for triggering the toggling between the current and the other objects. Adjusting the timing can easily be done by moving the Key Frames in the stage.
A/B Switching Mechanism
Switch Operation
  1. Animate out: Plays the X director of the current placeholder (fade out) in reverse.
  2. Flip: Swaps which side is $current and which is $other.
  3. Rename: Renames containers are renamed so external TCP commands always address $current/$other consistently.
  4. Animate in: Plays the X director of the new current placeholder (fade in).
Two Trigger Scenarios
Scenario
What happens
State change (e.g. $O → $IN)
The layer Director animates via GOTO_TRIO. Toggle keyframes on the timeline trigger AX/BX at the designed moment.
Object swap (same state, new content)
No Director movement. The switch action fires directly, cross-fading from current to other.
Parameter Reference
Basic
Parameter
Default
Description
Object
empty
Geometry pool path to load onto $other (for example, GEOM*MyDir/MyTemplate). Setting this triggers the load.
Manage stops
On
Rebuilds stop-points on loaded objects by calling ControlObject's restore_stops / remove_stops.
Auto-continue other object on Switch
On
Automatically sends continue_animation() to the object director after switch. Respects ControlObject's Filter Continues flag.
State control only
Off
Ignores all commands — only GOTO_TRIO state changes are processed. Optimisation for empty overlay scenes.
Controls video
Off
Allocates/clears clip channels per placeholder for ControlVideo integration.
Adaptive Scenes
Parameter
Default
Description
Support Box Transformation
Off
Initialises Box Transformation on Toggle and placeholder containers. Subscene mode only.
Support Flexbox layouting
Off
Creates Flexbox plugins on placeholders; uses active toggling instead of position animations.
Format Name
empty
Forces subscenes to render in a specific format. If empty, the master scene format is used.
Advanced
Revealed when Show advanced is enabled.
Parameter
Default
Description
Preload objects
template
List of geometry pool paths to preload (one per line, # = comment). Used with the Initialize action.
Director Command
empty
Raw director command string to execute on current/other object director.
Object director preview position
empty
Symbolic name or timecode for the show_position action.
Dummy
100
Internal parameter used to anchor the controlling director's animation channel. Do not modify.
Actions
Action
Description
Switch
Full A/B cross-fade transition: animate out current → swap → animate in new current.
Out
Animate out the current placeholder (reverse-play X director).
In
Animate in the current placeholder (forward-play X director).
Switch in
Swap other→current and animate in (no out animation on old).
Switch in preview
Hide current without animation, swap, seek to preview position.
Switch without animation
Swap visible containers instantly — no AX/BX playback.
Continue
Send continue_animation() to the current object director.
Continue Noanim
Seek object director to next stop without animation.
Default Keyframes
Generate GOTO_TRIO action channels (switch_in, out, switch) on the controlling director.
Delete Default Keyframes
Remove auto-generated keyframes. Run before re-generating after adding new stop points.
Initialize
Clear object cache and reload everything in the preload list.
Run director command on other
Execute the Director Command string against $other's object director.
Run director command on current
Execute the Director Command string against $current's object director.
Position object director at preview location
Seek the current object director to the timecode in Object director preview position.
Move object director to next stop
Seek the current object director to the next stop point.
Delete containers of all cached objects
Re-initialise placeholders and clear all cached containers from the tree.
Delete containers of inactive objects
Delete cached containers that aren't currently active on either A or B.
Default Keyframes
When Default Keyframes is invoked:
  1. Scans the controlling director (same name as the Toggle container) for all stop points.
  2. Creates three action channels on that director: switch_in, out, and switch.
  3. For each transition between stop points, inserts direction keyframes (±0.02s from boundaries) that tell AX/BX which way to play: forward (fade in) or reverse (fade out).
  4. Creates the four sub-directors (,AX, ,BX, ,AO, ,BO) with default one second alpha animations.
This is what enables GOTO_TRIO to automatically trigger the correct transition when jumping between states.
Object Caching
Toggle caches every loaded object. Requesting the same scene path again returns the cached version instantly — no Graphic Hub load occurs. The cache can be:
  • Pre-populated: List paths in the Preload objects text area and invoke Initialize.
  • Built on demand: Each first load is cached automatically.
  • Cleared: Use Delete containers of all cached objects or Delete containers of inactive objects.
Custom Transitions
Replace the default AX/BX alpha dissolve with any animation style:
  • Slide: Animates position X/Y instead of opacity.
  • Scale: Scales current to 0, scale other from 0 to 1.
  • 3D flip: Rotates containers on the Y-axis.
  • Wipe: Animates crop or stencil masks.
  • Dissolve with blur: Combines opacity with a blur plug-in.
The only constraint: AX and BX must always be identical animations.
Interaction with ControlObject
Interaction
Description
Stop-point management
Before loading, calls ControlObject.remove_stops. After loading, calls ControlObject.restore_stops to recreate stop points on the object director.
Continue filtering
Before sending continue_animation(), checks ControlObject's Filter Continues parameter. If true, suppresses the continue.
Video channel allocation
When Controls video is on, sends the allocated clip channel number to ControlObject.
Subscene root discovery
Locates the ControlObject plugin on the loaded scene's root to determine the subscene boundary.
Example: Master Scene with Two Layers
Scene "MasterScene"
├─ Container "BannerLyr" ← Toggle plugin
│ ├─ Director "BannerLyr" ← stops: $O (frame 0), $IN (frame 50)
│ ├─ Director "BannerLyr,AX" ← alpha 0→100 cross-fade
│ ├─ Director "BannerLyr,BX" ← identical to AX
│ ├─ Director "BannerLyr,AO" ← auto-managed
│ ├─ Director "BannerLyr,BO" ← auto-managed
│ ├─ $current
│ │ └─ $object (loaded scene A)
│ └─ $other
│ └─ $object (loaded scene B)
└─ Container "TickerLyr" ← Toggle plugin
├─ Director "TickerLyr" ← stops: $O, $TICKER
├─ ...AX, BX, AO, BO
├─ $current
└─ $other
Typical Broadcast Workflow
  1. Load: Set Toggle*object to a GEOM path → scene loads onto $other.
  2. Data: Push field values to $other$object*ControlObject*in.
  3. Take: Layer director executes GOTO_TRIO $O $IN → default keyframes trigger switch_in → Toggle cross-fades from nothing to the new graphic.
  4. Update: Push new data to $current$object*ControlObject*in (no animation needed).
  5. Swap: Load a different template onto $other, push data, then switch → A/B cross-fade.
  6. Out: Layer director executes GOTO_TRIO $IN $O → default keyframes trigger out → current fades away.
Technical Notes
  • The container must have a unique name before adding the Toggle plug-in. Director names are derived from the container's tree path.
  • Toggle only generates placeholders and directors if none exist from before.
  • After changing Support Box Transformation or Support Flexbox, the scene must be saved and reloaded to regenerate the Toggle structure.
  • In subscene mode, after SHOW $IN + switch INVOKE, a continue INVOKE must follow to complete the animation.
  • sitch_no_anim is an intentional internal name (not a typo in this documentation).
  • Box Transformation / adaptive scenes are supported in subscene mode only, not with merged geometries.
