Editing a template's layout makes it easy to create fill-in forms for journalist. With drag & drop functionality, creating new fill-in forms is quick and easy.
  • When a template is created, only the auto-generated form is displayed. The layout of this form cannot be modified.
  • Adding new tabs enables you to quickly create additional fill-in forms based on selected fields.
  • When adding new tabs, the default auto-generated form is accessible in the All tab. The auto-generated tab can be hidden from the Pilot Edge user.
  • In the additional tabs, it is possible to resize, move, edit, add and delete fields quickly.
Follow the steps below to get started.
Creating a Template
  1. Open or create a new template and add a scene.
  2. Click Fill-in form. The default view is then displayed:
  3. The toolbar in the middle has the following functions for the Fill-in-form:
    image-20250206-160649.png Add a new Tab (fill-in form). All tabs are visible in Viz Pilot Edge.
    image-20250206-160719.png Enter layout edit mode. Only enabled in additional tabs, not enabled for the default auto-generated All form. Click this to be able to move and resize fields.
    image-20250206-160801.png Allow temporary editing of read-only fields. This is only when working with the template in Template Builder, it is not stored anywhere.
    image-20250206-160855.png Reveal hidden fields. In the auto generated All mode, some system fields are also revealed (for instance the title, the auto generated title, the resolved concept and variant).
    image-20250206-160909.png Refresh HTML panel(s) in the template or the full HTML panel if the template is represented by a custom HTML panel.
Adding Alternative Layout Forms
To create an additional template representation, click the Create New Tab button :
Enter a new title for your new tab and click OK:
There are 3 ways of adding fields to the new form by selecting one of the following options:
  1. The All option in the dialog box, then all fields in the auto-generated form are added to the new form.
  2. The Selected option only includes selected fields in the new form.
  3. None creates a new empty form.
Moving, Resizing and Aligning Fields
  1. Click the ruler button to enter edit layout mode
  2. Move and resize by grabbing the edges of each field.
  3. Align fields by:
    1. Selecting multiple fields and UI components.
    2. Right click and select Align > Left, Right, Top or Bottom.
    3. The components are now aligned.
Renaming, Deleting and Reordering Tabs
Right click an additional tab (not the auto-generated All tab) to reveal the following functionality:
Now you can rename, reorder or delete each tab.
Hiding and Showing the Auto-Generated Tab
You can hide the auto-generated All tab from the Viz Pilot Edge user:
  • Click Template Properties.
  • Select Hide generated form:
