Communication with Tracking Hub
Tracking Hub provides a command interface similar to that offered by Viz Engine. The default port is 20000.
Command Syntax
<token> <location>[*<property>]* <command> [<parameter>]*
Where:
<token>: The token tells the receiver how to interpret the message, if an answer is expected etc.
<location>: Reference to an object or a collection of objects.
<property>: Reference property or properties or member objects contained in the root object or collection.
<command>: The command to be executed on the property or object.
<parameter>: Command parameter or parameters.
Tokens
> 0 | Client receives and answers carrying the same token. |
-1 | Client receives no answer. |
-2 | (only for message from Tracking Hub) Reserved for notifications. |
-3 | (only for message from Tracking Hub) Status message. |
Answer
You always get a string as an answer. It starts with a status code followed by the actual content (for example, XML) or an error message.
(0|1) [string|xml|message]
0 | Failure | Followed by an optional error message. |
1 | Success | Followed by an optional status message or an answer in a prearranged format. |
Long Pattern for Answer Handling
if (answer != null) { // Handle error answer if (CommandMessage.IsFailure(answer)) { if (CommandMessage.IsErrorMessage(answer)) { Log.Error("{0} returned an error: {1}", command, CommandMessage.ExtractMessage(answer)); return; } } // Handle success answer if (CommandMessage.IsSuccess(answer)) { // HANDLE VALID ANSWER HERE return; } Log.Error("{0} returned an invalid answer", command);} else { // No answer at all Log.Error("{0} returned no answer", command);}This pattern is implemented in: CommandMessage.IsSuccess(string answer, string command)Short Pattern for Answer Handling
if (CommandMessage.IsFailure(answer)) { // REPORT ERROR HERE return; // then bail out}Failure Messages
Note: Any command message may fail and return an error. It is because of the command interface having changed with a new version of Tracking Hub.
The most common generic error messages are:
Unknown Location
0 Unknown location: <location>
Returned if the top level location of the command message is unknown.
Unknown Property
0 Unknown property: <location>[*<property>]*
Returned if command message starts with a known location, but contains an unknown property in the following property path.
Unknown Command
0 Unknown command: <location>[*<property>]* <command>
Returned if command message starts with a known location and valid property path, but ends on an unknown command.
Commands
MAIN
Tracking Hub matching, available ports, IPs, etc. (MAIN*):
MAIN*COMPORTS GET = <portname>[,<portname>]*MAIN*PARAMETERLIST GET = <parametername>[,<parametername>]*MAIN*PROTOCOLS GET = <protocolname>[,<protocolname>]*MAIN*LOCAL_IPS GET = <ip>[,<ip>]*MAIN*VIZ_IP SET <ip> or <adaptername> GET = <adaptername>MAIN*TRACKING_IP SET <ip> or <adaptername> GET = <adaptername>MAIN*CONFIGURATIONS GET = [<name>[,<name>]*]?//MAIN START not used//MAIN STOP not used//MAIN*RUNNING GET = <bool> not usedMAIN*WRITE_LOG_FILE SET <bool> GET = <bool>MAIN*FORWARD_LOG SET <bool> GET = <bool>MAIN*LICENSE SET <key> GET = <name>,<number of cameras>,<days left> (name is either Cameras or Dongle, -1 means unlimited cameras/days)MAIN*DEBUGLEVEL SET <int> (range is 1 ... 10, 1 only emergency, 10 all) GET = <int>MAIN*DEBUGLEVEL++MAIN*DEBUGLEVEL--CONFIG
Store configuration on the Tracking Hub machine:
CONFIG EXISTS = 0|1CONFIG SAVECONFIG LOADCONFIG SET = <name>CONFIG GET = <name>CONFIG RESETCONFIG*BASE SAVECONFIG*BASE DISMISSSTUDIO
Base studio configuration (STUDIO*):
STUDIO GET = <xml>STUDIO*MODE SET FREE|AV|VIZ GET = SETSTUDIO*FREQUENCY SET 50|60|59.94 GET = SETSTUDIO*SHAPE SET LSHAPE_LEFT|LSHAPE_RIGHT|USHAPE|WALL|HOLE GET = SETSTUDIO*CYC SET <xml> GET = SETSTUDIO*TIMING GET = <bool>STUDIO*SENDDELAY GET = <int> [in ms] SET <int> [in ms]STUDIO*BUSYLOOP GET = <int> [type] SET <int> [type]TEMPLATES
Templates stored on the Tracking Hub machine (TEMPLATES*):
TEMPLATES*COUNT GET = <amount of templates>TEMPLATES LIST = <name1, name2, . . .>TEMPLATES*<name> GET = <xml>TEMPLATES*<name> SET <xml>TEMPLATES*<name> DELETETEMPLATES*<name> LOAD = <xml>TEMPLATES*<name> USE <name>TEMPLATES*<name> SAVE <ts_name1 ts_name2 . . . rig_name1 rig_name2 . . . 1 2>TRACKING SYSTEMS
Tracking Systems set up on the Tracking Hub machine (TRACKING_SYSTEMS*)
TRACKING_SYSTEMS*COUNT GET = <number of tracking systems>TRACKING_SYSTEMS CREATE <name>TRACKING_SYSTEMS DELETE <name>TRACKING_SYSTEMS XMLFILES GET = <string>TRACKING_SYSTEMS*<idx/name> GET = <xml>TRACKING_SYSTEMS*<idx/name> CONNECTTRACKING_SYSTEMS*<idx/name> DISCONNECTTRACKING_SYSTEMS*<idx/name>*INDEX GET = <index>TRACKING_SYSTEMS*<idx/name>*NAME SET <name> GET = <name>TRACKING_SYSTEMS*<idx/name>*SLOTINDEX SET <slotindex> GET = <slotindex>TRACKING_SYSTEMS*<idx/name>*PROTOCOL SET <protocolname> GET = <protocolname>TRACKING_SYSTEMS*<idx/name>*NETUSE SET <netuse> GET = <netuse>TRACKING_SYSTEMS*<idx/name>*COMPORT SET <name> GET = <name>TRACKING_SYSTEMS*<idx/name>*BAUDRATE SET <baud> GET = <baud>TRACKING_SYSTEMS*<idx/name>*PARITY SET <baud> GET = <baud>TRACKING_SYSTEMS*<idx/name>*STOPBITS SET <baud> GET = <baud>TRACKING_SYSTEMS*<idx/name>*DATASIZE SET <baud> GET = <baud>TRACKING_SYSTEMS*<idx/name>*HOST SET <ip> GET = <ip>TRACKING_SYSTEMS*<idx/name>*PORT SET <port> GET = <port>TRACKING_SYSTEMS*<idx/name>*XMLFILE SET <string> GET = <string>TRACKING_SYSTEMS*<idx/name>*STATUS GET = DISCONNECTED|NOT_RECEIVING|BAD_TIMING|GOOD_TIMING//only in running modeTRACKING_SYSTEMS*<idx/name>*PARAMETERS GET = <parametername>[,<parametername>]*TRACKING_SYSTEMS*<idx/name>*SENDRAWDATA SET <bool>TRACKING_SYSTEMS*<idx/name>*RAWDATA_OFFSET <parametername> ACTTRACKING_SYSTEMS*<idx/name>*RAWDATA_OFFSET <parametername> SET <int>// not in use any longer//TRACKING_SYSTEMS*<idx/name>*SENDDELAY GET = <ms>// SET <ms>//this command switches hexdumploggingTRACKING_SYSTEMS*<idx/name>*HEXLOG SET <bool> GET = <bool>TRACKING_SYSTEMS*<idx/name>*TICKCOUNT SET <parametername, value>[,<parametername, value>] GET = <parametername, value>[,<parametername, value>]TRACKING_SYSTEMS*<idx/name>*RCVTIMECORR SET <bool> GET = <bool>LATTICES
Lattices set up on the Tracking Hub machine (LATTICES*):
LATTICES*COUNT GET = <zero-based index>LATTICES CREATE <name>LATTICES DELETE <name>LATTICES LENSFILES GET = <string>LATTICES LENSFILES RELOADLATTICES*<idx/name> CREATE PARENT|CHILD <childname> LATTICES*<idx/name> GET = <xml>LATTICES*<idx/name>*INDEX GET = <index> LATTICES*<idx/name>*NAME SET <string> GET = <string>LATTICES*<idx/name>*FILTER_ZOOM SET <bool> GET = <bool>LATTICES*<idx/name>*TYPE SET SIMPLE_CAM|OBJECT|LATTICE GET = SIMPLE_CAM|OBJECT|LATTICE LATTICES*<idx/name>*SLOTINDEX SET <slotindex> GET = <slotindex>LATTICES*<idx/name>*<parameter>*NAME SET <string> GET = <string> *OFFSET SET <float> GET = <float> *INVERT SET <bool> GET <bool> *DELAY SET <float> GET <float>LATTICES*<idx/name>*TRACKINGDELAY SET <frames(float)>LATTICES*<idx/name>*VISUAL_XML SET <xml> GET = <xml>LATTICES*<idx/name>*CALIBRATION SET <bool> GET = <bool>LATTICES*<idx/name>*CALIBRATIONDONE GET = <bool>LATTICES*<idx/name>*CALIBRATION_RANGE GET = <zoom_min> <zoom_max> <zoom> <focus_min> <focus_max> <focus>LATTICES*<idx/name>*LENSRANGE SET <lensrange_min> <lensrange_max> GET = <lensrange_min> <lensrange_max>LATTICES*<idx/name>*SCALEVAUES SET <ScXNear, ScXWide, ScYNear, ScYWide> GET = <ScXNear, ScXWide, ScYNear, ScYWide>LATTICES*<idx/name>* LENSFILE SET <string> GET = <string>LATTICES*<idx/name>* LENSFILE_LENSEXT SET <string> GET = <string>SERVICES
Services set up on the Tracking Hub machine (SERVICES*):
SERVICES*COUNT GET = <zero-based index>SERVICES*BY_INDEX*<idx> GET = <xml> START STOPSERVICES*BY_INDEX*<idx>*SLOTINDEX GET = <slotindex> SET <slotindex>SERVICES*BY_INDEX*<idx>*RUNNING GET = <bool>SERVICES*BY_ID*<service_id> GET = <xml> START STOPSERVICES*BY_ID*<service_id>*SLOTINDEX GET = <slotindex> SET <slotindex>SERVICES*BY_ID*<service_id>*RUNNING GET = <bool> SERVICES ADD PARAMETER ALL <ip> <port> = <service_id>SERVICES ADD PARAMETER <lattice_name> <ip> <port> = <service_id>SERVICES ADD TRACKING_TIMING <ts_name> <ip> <port> = <service_id>SERVICES ADD COMMUNICATION_TIMING <service_id> <ip> <port> = <service_id>SERVICES ADD CAMERA <lattice_name> <ip> <port> <cameranumber> = <service_id>SERVICES ADD OBJECT <lattice_name> <ip> <port> = <service_id>SERVICES ADD TIMECODE <timcode> <ip> <port> = <service_id>SERVICES REPLACE <service_id> (TRACKING_TIMING|COMMUNICATION_TIMING) (<ts_name>|<service_id>) <ip> <port> = <service_id>SERVICES REPLACE <service_id> (PARAMETER|OBJECT|TIMCODE) (<lattice_name>|<timcode>) <ip> <port> = <service_id>SERVICES REPLACE <service_id> CAMERA <lattice_name> <ip> <port> <cameranumber> = <service_id>SERVICES REMOVE <service_id>SERVICES REMOVE_ADDR <ip>SERVICES REMOVE_ALLROUTERS
Configure routers controlled by Tracking Hub (ROUTERS*):
List Available Router Models
ROUTERS*MODEL_LIST GET = <model>[,<model>]*Manage Routers
ROUTERS ADD <model> <name> = <index>ROUTERS REMOVE <name> | <index>ROUTERS*COUNT GET = <count>Configure Individual Routers
ROUTERS*<idx/name> GET = <xml>ROUTERS*<idx/name>*INDEX GET = <index>ROUTERS*<idx/name>*NAME SET <string> GET = <string>ROUTERS*<idx/name>*MODEL SET <model> GET = <model>ROUTERS*<idx/name>*AB_MODE SET <mode> GET = <mode>ROUTERS*<idx/name>*NETUSE SET <netuse> GET = <netuse>ROUTERS*<idx/name>*COMPORT SET <name> GET = <name>ROUTERS*<idx/name>*BAUDRATE SET <baud> GET = <baud>ROUTERS*<idx/name>*PARITY SET <baud> GET = <baud>ROUTERS*<idx/name>*STOPBITS SET <baud> GET = <baud>ROUTERS*<idx/name>*DATASIZE SET <baud> GET = <baud>ROUTERS*<idx/name>*HOST SET <ip> GET = <ip>ROUTERS*<idx/name>*PORT SET <port> GET = <port>ROUTERS*<idx/name> CONNECTROUTERS*<idx/name> DISCONNECTROUTERS*<idx/name>*CONNECTED GET = <boolean>ROUTERS*<idx/name>*INPUTS*<idx>*NAME SET <string> GET = <string>ROUTERS*<idx/name>*OUTPUTS*<idx>*NAME SET <string> GET = <string>ROUTERS*<idx/name>*CURRENT_PRESET SET <string> GET = <string>Configure Presets of Individual Routers
ROUTERS*<idx/name>*PRESETS CREATE <name> = <index>ROUTERS*<idx/name>*PRESETS DELETE <name>|<index>ROUTERS*<idx/name>*PRESETS*COUNT GET = <count>ROUTERS*<idx/name>*PRESETS*<idx/name> GET = <xml>ROUTERS*<idx/name>*PRESETS*<idx/name>*NAME SET <string> GET = <string>ROUTERS*<idx/name>*PRESETS*<idx/name> CONNECT <input-index> <output-index>ROUTERS*<idx/name>*PRESETS*<idx/name> DISCONNECT <input-index> <output-index>ROUTERS*<idx/name>*PRESETS*<idx/name>*CAMERAS ADD <ip> <port> <cameranumber> = <index>ROUTERS*<idx/name>*PRESETS*<idx/name>*CAMERAS REMOVE <index>ROUTERS*<idx/name>*PRESETS*<idx/name>*CAMERAS*COUNT GET = <int>ROUTERS*<idx/name>*PRESETS*<idx/name>*CAMERAS*<idx> GET = <xml>ROUTERS*<idx/name>*PRESETS*<idx/name>*GPIIO ADD <devicename> <port> <pin> <pressed> GET = <devicename> <port> <pin> <pressed>ROUTERS*<idx/name>*PRESETS*<idx/name>*GPIIO REMOVEROUTERS*<idx/name>*MANUAL_CONTROL GET = <xml>ROUTERS*<idx/name>*MANUAL_CONTROL*ENABLED SET <boolean> GET = <boolean>ROUTERS*<idx/name>*MANUAL_CONTROL CONNECT <input> <output>ROUTERS*<idx/name>*MANUAL_CONTROL DISCONNECT <input> <output>Delays per Router
ROUTERS*<idx/name>*PRESET_DELAY SET <double> GET = <double>ROUTERS*<idx/name>*ENGINE_DELAY SET <double> GET = <double>GPIIO
GPIIO used on the Tracking Hub machine (gpiio).
GPIIO*COUNT GET = <count>GPIIO*MONITOR STARTGPIIO*MONITOR STOPGPIIO*MONITOR GET = <boolean>GPIIO*<idx/name> GET = <devicename> <count inputports> <count outputports>GPIIO*<idx/name>*INDEX GET = <index>GPIIO*<idx/<name>*NAME GET = <string> Notifications (only sent from Tracking Hub) if gpi triggered when monitoring is onGPIIO*MONITOR PRESSED <devicename> <port> <pin>GPIIO*MONITOR RELEASED <devicename> <port> <pin>POST
Setup of the Tracking Hub post system.
Set the Timecode Sources for Live and Post
POST*LIVE_SOURCE SET <string> GET = <string>POST*POST_SOURCE SET <string> GET = <string>POST*TIMECODE_SOURCES GET <string>[,<string>]*Session Commands
POST*SESSION CREATE <string>(create a new session) START (starts recording) STOP (stops recording) GET_LIST = <string>[,<string>] LOAD <string> DELETE <string> INFO_GET = <string>;[,<string>]*Notifications
Loading saved session file progress as a percentage FILE_PROGRESS <float>. Loading of saved session file is complete FILE_FINISH.
Recording and Replay Commands
POST*PARAMETER_RECORDING GET <Parameter Name> = 1 (recording on) | 0 (recording off) SET <Parameter Name> <0|1>POST*PARAMETER_REPLAY GET <Parameter Name> = 1 (replay on) | 0 (replay off) SET <Parameter Name> <0|1> GET_DELAY <Parameter Name> = <float> SET_DELAY <float>TRACKING_SYSTEMS*<name>*RECORDING GET = 1 (recording on) | 0 (recording off) SET <0|1>TRACKING_SYSTEMS*<name>*REPLAY GET = 1 (replay on) | 0 (replay off) SET <0|1>TRACKING_SYSTEMS*<index>*RECORDING GET = 1 (recording on) | 0 (recording off) SET <0|1>TRACKING_SYSTEMS*<index>*REPLAY GET = 1 (replay on) | 0 (replay off) SET <0|1>TRACKING_SYSTEMS*<name>*REPLAY GET_DELAY = <float> SET_DELAY <float>TRACKING_SYSTEMS*<index>*REPLAY GET_DELAY = <float> SET_DELAY <float>SERVICES*RECORDING GET <service id> = 1 (recording on) | 0 (recording off) SET <service id> <0|1>SERVICES*REPLAY GET <service id> = 1 (replay on) | 0 (replay off) SET <service id> <0|1>SERVICES*REPLAY GET_DELAY <service id> = <float>SERVICES*REPLAY SET_DELAY <service id> <delay>LENSFILE
Lensfile, load, save and change on the Tracking Hub machine (LENSFILE*).
LENSFILE*LOGIN <pwd> = <xml_lensfile> ??? correct error handling ???LENSFILE*NEW LENSFILE*LOCK <service_id> = <LockID>LENSFILE*UNLOCK <LockID >LENSFILE*XML_GET <LockID > = <xml_lenfsile>LENSFILE*SELECT <lensfilename> = lenfile (binary) loaded for editLENSFILE*SAVE <LockID,>LENSFILE*SAVEAS <LockID, name>LENSFILE*GROUP SELECT <LockID parameter>LENSFILE*GROUP NEW <LockID parameter> LENSFILE*GROUP ADD < LockID , parameter >LENSFILE*GROUP DELETE < LockID , parameter>LENSFILE*GROUP PARAMETERMOVE <LockID , parameter groupID >LENSFILE*GROUP PARAMETERMOVE <LockID , parameter > //move into a new group LENSFILE*PARAMETER<parameter>VALUEADD< LockID , zoom,focus >LENSFILE*PARAMETER<parameter>VALUEDEL< LockID , zoom,focus >LENSFILE*PARAMETER<parameter>VALUECHANGE< LockID , zoom,focus,newvalue>LENSFILE*ACTIVE GET = all active servicesLENSFILE*PROXY SEND<LockID,string>LENSFILE*PROXY REQ < LockID string> = <answer>
