Configuration Panel
The Configuration Panel is used to save and load Studio configuration profiles, select modes of operation including frequency, and to set some user interface options.
Menu options:
Open: Open a Tracking Hub configuration file. The name of the currently loaded configuration file will always be displayed in the top bar, between the application’s name and main menu.
Save: Save the current Studio configuration.
Save As: Save the current Studio configuration with a new name.
Reset: Reset the current Studio configuration. Note that the loaded configuration file is only changed if save is clicked after resetting the configuration.
View Log: Open or close the Log Panel.
View Timing Analysis: Open the Timing Analysis Window.
Frequency: Select the production frequency;
50 Hz,60 Hzor59.94 Hz. -
Synchronization Mode: Select synchronization mode for the Tracking Hub:
Freerun: No synchronization. The Tracking Hub uses its own time base, corresponding with the configured frequency.
AV-Card: Synchronization is done by an installed Plura card.
Viz Engine: Synchronized with Viz Engine, running on the same computer.
Tip: If the selected synchronization mode is followed by a red box with a white horizontal line, this indicates synchronization issues.
