System Requirements
This section detail the system requirements.
Syncronization
The Tracking Hub needs some sort of synchronization method on the machine it is installed. This can be:
  • a running Viz Engine installation, or
  • an installed Plura synchronization card.
If sync sources is not found, the Tracking Hub can still be used in “free running” mode. Free running is not intended and should not be used for production. It can, however, be used to experiment with tracking on a laptop. For use in production either Viz Engine or Plura synchronization is needed.
Minimum Hardware Configuration
  • Minimum 4 GB Ram
  • Dual-Core Intel or AMD CPU
  • Min 10 gigabyte free disk space
Recommended Hardware and Software Configuration
  • 8 GB Ram
  • Quad-Core Intel or AMD CPU
  • Windows 7 Pro 64 Bit
  • 10 gigabyte free disk space
Supported Hardware and Software
  • Windows 7 32-Bit and 64-Bit
  • Viz Engine 3.7.2 (either 32-Bit or 64-Bit) or later
  • Plura PCL-PCI and PCL-PCIe (L, LV, 3G) timecode reader cards (Driver 5.16)
  • Studio Manager requires .NET framework 4.5.1 or higher.
