Viz Virtual Studio Folders
This section details the location of the Viz Virtual Studio default installation and data folders.
This section contains details on the following topics:
Installation Folders
The default installations folders are:
| Windows System | Viz Virtual Studio Platform | Installation Folder |
Windows 7 32-bit |
32 bit |
64 bit |
Windows 7 64-bit |
32 bit |
64 bit |
Data Folders
Files which are created or can be modified are located at %ProgramData%\vizrt\VizTH:
Config files
Crash dump files
Temporary files are located at: %TMP%\vizrt\viz3, which usually resolves to C:\Users\<user name>\AppData\Local\Temp\vizrt\Viz3. This folder is referenced as <viz temp folder> throughout this User Guide.
